Vishwa Mishra
Symptoms
Troubleshooting Jumbo Frames /Input/Output errors on N5k/N2k
Topology
I have fex connected to eth104/1/10 to N5k-2
++++Currently as we could see there is no traffic or errors on interface
N5k-2# show interface ethernet 104/1/10
Ethernet104/1/10 is up
  Last clearing of "show interface" counters 00:01:04
  30 seconds input rate 0 bits/sec, 0 packets/sec
  30 seconds output rate 64 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 1.33 Gbps, 52.47 Kpps; output rate 120 bps, 0 pps
  RX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 unicast packets  3 multicast packets  0 broadcast packets
    3 output packets  930 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  0 interface resets
++++There are no stomp or crc error on the asic currently
N5k-2# show hardware internal carmel asic 0 interrupt match mtu
Slot 0 Carmel 0 interrupt source status:
Interrupt name                                                  |Status
Done.
++++Now i will send jumbo frame size 1600 from IXIA connected to port 104/1/10 on N5k-2
++++You could see frame as counted as jumbo on the HIF port 104/1/10
  Hardware: 1000/10000 Ethernet, address: f84f.57b9.84cb (bia f84f.57b9.84cb)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  reliability 255/255, txload 1/255, rxload 5/255
  Encapsulation ARPA
  Port mode is access
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is on
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 00:25:14
  Last clearing of "show interface" counters 00:04:39
  30 seconds input rate 60392440 bits/sec, 4718 packets/sec
  30 seconds output rate 160 bits/sec, 0 packets/sec
    input rate 218.38 Mbps, 457 pps; output rate 120 bps, 0 pps
  RX
    136725 unicast packets  0 multicast packets  0 broadcast packets
    136724 input packets  218758400 bytes
    136722 jumbo packets  0 storm suppression bytes
    0 Rx pause
  TX
    0 unicast packets  15 multicast packets  0 broadcast packets
    15 output packets  4650 bytes
    0 jumbo packets
    0 Tx pause
  0 interface resets
++++On fex we could see traffic is received on Hif9 and send to Nif0
++++I could see frames are received on HIF9 ( 104/1/10)
fex-104# show platform software woodside rmon 0 hif9 for counter RX_PKT_1519 ( since i am sending packects size 1600)
++++We could see that frames are counted as TX error on NIF0 port
fex-104# show platform software woodside rmon 0 ni0
++++Fex interface (eth1/2) see these frames as rx jumbo and input error
N5k-2# show interface ethernet 1/2
Ethernet1/2 is up
  Hardware: 1000/10000 Ethernet, address: 002a.6a6a.4f09 (bia 002a.6a6a.4f09)
  reliability 128/255, txload 35/255, rxload 37/255
  Encapsulation ARPA
  Port mode is fex-fabric
  Input flow-control is off, output flow-control is off
  EtherType is 0x8100
  Last link flapped 02:41:50
  Last clearing of "show interface" counters 00:08:57
  30 seconds input rate 1779506656 bits/sec, 139018 packets/sec
  30 seconds output rate 144 bits/sec, 15 packets/sec
    input rate 1.46 Gbps, 114.02 Kpps; output rate 1.40 Gbps, 114.02 Kpps
  RX
    2501 unicast packets  36368655 multicast packets  0 broadcast packets
    36371156 input packets  58192101472 bytes
    36369824 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  36368484 CRC  0 no buffer
    36368484 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 Rx pause
  TX
    1217 unicast packets  36368658 multicast packets  0 broadcast packets
    36369875 output packets  55862244410 bytes
    83 jumbo packets
    83 output errors  0 collision  0 deferred  0 late collision
    0 Tx pause
  0 interface resets
 ++++Now lets check the Carmel and Forwarding asic and see if the interrupt are triggered on those in the right directions
  N5k-2# show hardware internal carmel all-ports
Carmel Port Info:
name   |log|car|mac|flag|adm|opr|m:s:l|ipt|fab|xcar|xpt|if_index|diag|ucVer
xgb1/1 |0  |0  |0 -|b7  |dis|dn |0:0:f|0  |92 |0   |0  |1a000000|pass| 0.00
xgb1/2 |1  |0  |1 p|b7  |en |up |1:1:f|1  |88 |0   |0  |1a001000|pass| 0.00
xgb1/3 |2  |0  |2 p|b7  |dis|dn |2:2:f|2  |93 |0   |0  |1a002000|pass| 0.00
xgb1/4 |3  |0  |3 p|b7  |en |up |3:3:f|3  |89 |0   |0  |1a003000|pass| 0.00
xgb1/5 |4  |0  |4 p|b7  |dis|dn |4:4:f|4  |90 |0   |0  |1a004000|pass| 0.00
xgb1/6 |5  |0  |5 -|b7  |dis|dn |5:5:f|5  |94 |0   |0  |1a005000|pass| 0.00
++++Based on the above output my input and output port is mapped to asic 0 and fw instance 1 ( for ingress ) and 3 ( for egress)
++++As expected we see mtu violation on ingress
car_bm1_INT_err_ig_mtu_vio                                      |Set
and frame is stopmed on ingress and egress asic ( fw 1 and 3)
N5k-2# show hardware internal carmel asic 0 interrupt match stomp
car_fi1_INT_fi_rx_pkt_crc_stomp                                 |Set
car_fi3_INT_fi_rx_pkt_crc_stomp                                 |Set
car_bm1_INT_norm_igrd_crc_stomp                            |Set
car_bm1_INT_norm_egrd_crc_stomp                           |Set
car_bm3_INT_norm_egrd_crc_stomp                            |Set
car_fw1_INT_ig_pkt_err_eth_crc_stomp                        |Set
car_fw3_INT_eg_pkt_err_eth_crc_stomp                      |Set
car_mm1_pb_INT_buf_ecc_crc_rx_crc_stomp              |Set
car_mm1_pb_INT_buf_ecc_crc_tx_crc_stomp                |Set
car_mm1_xe_INT_xg_rx_crc_stomped                          |Set
car_mm3_pb_INT_buf_ecc_crc_tx_crc_stomp              |Set
Done.
and counted as output jumbo and error on exit interface 1/4
N5k-2# show interface ethernet 1/4
Ethernet1/4 is up
  Hardware: 1000/10000 Ethernet, address: 002a.6a6a.4f0b (bia 002a.6a6a.4f0b)
  reliability 255/255, txload 43/255, rxload 1/255
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Last link flapped 02:36:42
  Last clearing of "show interface" counters 00:12:23
  30 seconds input rate 856 bits/sec, 1 packets/sec
  30 seconds output rate 1694861136 bits/sec, 138826 packets/sec
    input rate 648 bps, 1 pps; output rate 1.70 Gbps, 138.79 Kpps
  RX
    0 unicast packets  1156 multicast packets  0 broadcast packets
    1156 input packets  87271 bytes
    0 Rx pause
  TX
    0 unicast packets  64874742 multicast packets  0 broadcast packets
    64874742 output packets  98998841184 bytes
    64874730 jumbo packets
    64874730 output errors  0 collision  0 deferred  0 late collision
    0 Tx pause
  0 interface resets
 ++++When it reach N5k-1 eth1/4 its counted as input error
  N5k-1# show interface ethernet 1/4
Ethernet1/4 is up
  Hardware: 1000/10000 Ethernet, address: 002a.6a62.b06b (bia 002a.6a62.b06b)
  reliability 1/255, txload 1/255, rxload 43/255
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Last link flapped 02:37:28
  Last clearing of "show interface" counters 00:34:57
  30 seconds input rate 1695456184 bits/sec, 138874 packets/sec
  30 seconds output rate 856 bits/sec, 1 packets/sec
    input rate 1.70 Gbps, 138.88 Kpps; output rate 648 bps, 1 pps
  RX
    0 unicast packets  162427934 multicast packets  0 broadcast packets
    162427934 input packets  247864983219 bytes
    162427899 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  162427899 CRC  0 no buffer
    162427899 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 Rx pause
  TX
    0 unicast packets  3252 multicast packets  0 broadcast packets
    3252 output packets  245671 bytes
    0 jumbo packets
    0 Tx pause
  0 interface resets
++++no mtu voilation on N5k-1
N5k-1# show hardware internal carmel asic 0 interrupt match mtu
Done.
++++checking the Carmel and mac asic mapping for incoming ( eth1/4) and outgoing (eth1/1) interface
N5k-1# show hardware internal carmel all-ports
Carmel Port Info:
xgb1/1 |0  |0  |0 p|b7  |en |up |0:0:f|0  |92 |0   |0  |1a000000|pass| 0.00
xgb1/2 |1  |0  |1 -|b7  |dis|dn |1:1:f|1  |88 |0   |0  |1a001000|pass| 0.00
++++As could we seen that crc and stomp is marked for ingress and egress asic.
N5k-1# show hardware internal carmel asic 0 interrupt match stomp
car_fi0_INT_fi_rx_pkt_crc_stomp                                 |Set
car_bm0_INT_norm_egrd_crc_stomp                           |Set
car_bm3_INT_norm_igrd_crc_stomp                                 |Set
car_fw0_INT_eg_pkt_err_eth_crc_stomp                            |Set
car_fw3_INT_ig_pkt_err_eth_crc_stomp                            |Set
car_mm0_pb_INT_buf_ecc_crc_tx_crc_stomp                         |Set
car_mm3_pb_INT_buf_ecc_crc_rx_crc_stomp                         |Set
++++ Packets fron N5k-1 is marked as tx output error
N5k-1# show interface ethernet 1/1
Ethernet1/1 is up
  Hardware: 1000/10000 Ethernet, address: 002a.6a62.b068 (bia 002a.6a62.b068)
  Encapsulation ARPA
  EtherType is 0x8100
  Last link flapped 01:32:39
  Last clearing of "show interface" counters 00:37:37
  30 seconds input rate 54408 bits/sec, 5 packets/sec
  30 seconds output rate 1705846216 bits/sec, 138817 packets/sec
    input rate 52.11 Kbps, 1 pps; output rate 1.71 Gbps, 138.82 Kpps
  RX
    13026 unicast packets  712 multicast packets  0 broadcast packets
    13738 input packets  14833014 bytes
    8420 jumbo packets  0 storm suppression bytes
    0 Rx pause
  TX
    4762 unicast packets  183981116 multicast packets  1 broadcast packets
    183985879 output packets  282594803247 bytes
    183980383 jumbo packets
    183980383 output errors  0 collision  0 deferred  0 late collision
    0 Tx pause
  0 interface resets
  ++++From Fex we could see the input and output rate received on ni1 and send hif9
fex-104# show platform software woodside rate
++++Checking the rx error on ni1 interface
fex-104# show platform software woodside rmon 0 ni1
++++Checking the tx error on hif9
This finishes the END to END tracking of jumbo frame ,thanks for looking and feedback!!
