Kundan Prasad
Copy the new IOS image to switch
copy tftp: bootflash:
verify the image
verifiy bootflash:IOS-NAME
If 4500 is connected in VSS then follow below steps,
  1. copy bootflash: slavebootflash:
  2. verify slavebootflash:IOS-NAME
Set the boot register to 0×2102 for the switch to boot from the BOOT variable.
config-register 0x2102
If it is not set then it will try to use 0x2101 setting and will lead to use the first file found in the bootflash. If there is no other IOS then ignore this else configure the register with 0x2102. 0x2102 will use the boot system command which you will set in next step.
Set the boot variable to new image
no boot system flash bootflash:IOS-NAME
Save the config
write
Verify the bootvar path
show bootvar
Now you are all set to reboot the device !
Leo Laohoo
Verify "what"?  The option to verify using MD5 is missing.
