Janel Kratky
Join us for the next Cisco  IOS Advantage Webinar, a 2-hour technical discussion on Locator/ID  Separation Protocol (LISP).
The Locator/ID Separation Protocol (LISP)  implements a new routing architecture through a set of protocols that  utilize a level of indirection to separate an IP address into two  namespaces: Endpoint Identifiers (EIDs), which are assigned to  end-hosts, and Routing Locators (RLOCs), which are assigned to devices  (primarily routers) that make up the global routing system. By  separating the host address (EID) from its location (RLOC), LISP  provides key benefits in many network environments, including mobility  environments where hosts are now able to move anywhere within the  network while keeping their IP (EID) while changing their location  (RLOC).
LISP  Host Mobility addresses today's enterprise data center and campus  mobility challenges. This session discusses how next generation  technologies such as LISP and OTV solve the networking issues associated  with VM mobility and multi-tenant segmentation in the data center. An  overview of the technologies and their solutions for LAN extension,  mobility and segmentation is provided.
Agenda
  • Business Drivers
  • Brief  LISP Architectural Overview
  • Data Center Host Mobility  Deployment Use Case
  • Enterprise "Vision" for LISP
  • LISP  Development Status
  • Conclusion
Logistics
Date: October 3, 2012
Time:  8am Pacific Time
Venue: WebEx (Replay available at  WebEx link)
Slides:http://www.slideshare.net/getyourbuildon/using-lisp-to-solve-todays-ip-host-mobility-challenges-ios-advantage-webinar
Send any  questions to ask_iosadvantage@cisco.com. For  more information on upcoming Cisco IOS Advantage Webinars, go to: http://www.cisco.com/go/iosadvantage. Follow us on Twitter @GetYourBuildOn
Janel Kratky
If you are attending Cisco Live London, you may be interested in attending the Advanced LISP Techtorial Session (TECIPM-3191).
Session Listings: https://www.ciscolivelondon.com/scheduler/eventguide/publicScheduleByType.jsp?ts=1348479813036
Registration: http://www.ciscolive.com/london/registration-packages/
