TCC_2
Community Member
Introduction
LED Patterns on Cisco Access Points
Resolution
If your access point is not communicating, check the three LED indicators on the top panel. You can use them to assess the unit's status quickly.
The LEDs signals have the following meanings (for additional details refer to Table:
•The Ethernet LED signals traffic on the wired LAN, or Ethernet infrastructure. This LED is normally green when an Ethernet cable is connected, and blinks green when a packet is received or transmitted over the Ethernet infrastructure. The LED is off when the Ethernet cable is not connected.
•The status LED signals operational status. Steady green indicates that the access point is associated with at least one wireless client. Blinking green indicates that the access point is operating normally but is not associated with any wireless devices.
•The radio LED blinks green to indicate radio traffic activity. The light is normally off, but it blinks green whenever a packet is received or transmitted over the access point's radio.
Message
type
Ethernet
LED
Status
LED
Radio
LED
Meaning
Boot loader status
Green
Green
DRAM memory test.
Amber
Red
Board initialization test
Blinking green
Blinking green
Flash memory test.
Amber
Green
Ethernet initialization test.
Green
Green
Green
Starting Cisco IOS.
Association status
Green
At least one wireless client device is associated with the unit.
Blinking green
No client devices are associated; check the unit's SSID and WEP settings.
Operating status
Green
Blinking green
Transmitting/receiving radio packets.
Green
Ethernet link is operational.
Blinking green
Transmitting/receiving Ethernet packets.
Boot Loader Errors
Red
Red
DRAM memory test failure.
Red
Red
File system failure.
Red
Red
Ethernet failure during image recovery.
Amber
Green
Amber
Boot environment error.
Red
Green
Red
No Cisco IOS image file.
Amber
Amber
Amber
Boot failure.
Operation Errors
Green
Blinking amber
Maximum retries or buffer full occurred on the radio.
Blinking amber
Transmit/receive Ethernet errors.
Blinking amber
General warning.
Configuration Reset
Amber
Resetting the configuration options to factory defaults.
Failure
Red
Red
Red
Firmware failure; try disconnecting and reconnecting unit power.
Firmware Upgrade
Red
Loading new firmware image.
Problem Type
LEDs
Products
Access point
Product OS
IOS
VxWorks
Reference
Troubleshooting on the 350 Series Access Point
Troubleshooting on the 1100 Series Access Point
Troubleshooting on the 1200 Series Access Point
Checking the Autonomous Access Point LEDs
Troubleshooting Autonomous Access Points
Checking the Lightweight Access Point LEDs
Troubleshooting Lightweight Access Points
Cisco Aironet 1100 Series Access Point Hardware Installation Guide, OL-4309-05
