Rajan Parmar
We can understand all possible ways of wireless communication in four cases in the following ways  :
Case 1: we talk of AP     to   AP   communication
Case 2: we talk of client to client communication (when    AP is involved) : from wireless to the AP
Case 3: we talk of client to client communication (when    AP is involved) : from AP       to the wireless
Case 4: we talk of client to client communication (when no AP is involved)
In Wireshark :
To filter all frames pertaining to case 1, use filter as wlan.fc.ds == 0x11
To filter all frames pertaining to case 2, use filter as wlan.fc.ds == 0x10
To filter all frames pertaining to case 3, use filter as wlan.fc.ds == 0x01
To filter all frames pertaining to case 4, use filter as wlan.fc.ds == 0x00
These four cases are represented via bits in the following way :
      wlan.ra     wlan.ta
      Receiver    Transmitter
      To DS  <-   From DS
Case 1: 1            1  either do      move To DS or move From DS) ie, AP to AP communication, as in Mesh Setup.
Case 2: 1            0                                                 Specific   wireless client to AP
Case 3: 0            1                                                 AP !to all wireless clients but specific wirless client
Case 4: 0            0  or     do not  move To DS or move From DS) ie, AP  to all wireless clients (broadcast)
IF
1 indicates AP (bssid)
0 indicates WirelessClient (w/c)
THEN
        Destination<- Source
        Receiver <- Transmitter
 filter wlan.fc.ds == 0x   1 1  will indicate the traffic in the direction       AP  <- AP
 filter wlan.fc.ds == 0x   1 0  will indicate the traffic in the direction       w/c <- AP
 filter wlan.fc.ds == 0x   0 1  will indicate the traffic in the direction       AP  <- w/c
 filter wlan.fc.ds == 0x   0 0  will indicate the traffic in the direction       w/c <- w/c  (without AP)
Legend:
w/c1: first  wireless client
w/c2: second wireless client
src : when client is the source      of communication.
dst : when client is the destination of communication.
! means "not"
Say, there are two wireless clients talking , where first wireless client sends message to the second wireless client
           Address 1   Address 2    Address 3    Address 4
           Receiver    Transmitter  Destination  Source
1 1      AP2(bssid)    AP1(bssid)   w/c2         w/c1
1 0      w/c2(dst)     AP (bssid)   w/c1(src)
0 1      AP (bssid)    w/c1(src)    w/c2(dst)
0 0      w/c2(dst)     w/c1(src)    AP (bssid)
In other words, the same information can be understood in the following ways:
In wireless communication, we talk on terms of wireless clients and Access Points ( known as DS )
(A) Wireless Communication Types:
AP     to AP     communication.
Client to Client communication. (either when AP is involved or AP is not involved)
(B) So, there comes out to be four subtypes of wireless communication:
if (   AP  -  AP   )         Case 1: (when in mesh mode)
if ( client-client ){
    if ( AP is involved){
         if (wireless to AP) Case 2:
         if (AP to Wireless) Case 3:
    if (!AP is involved)     Case 4: (ad-hoc n/w )
(C)
Wireless frames are always sent from a transmitting device to a receiving device.
( while reaching all the way to the final destination )
RA - indicates the address of the device, to which transmission of frame should be sent, so that the Final Destination can get it.
TA - indicates the address of the device,    which transmitted the data ( not necessarilly, the originator of the transmitted data, who actually transmitted the frame
Address1 field always contains the RA. wlan.ra
Address2 field always contains the TA. wlan.ta
-if (bridges in use )                    {Address 4 is used }
-else
   if ( RA is not the final recipient ) { Address 3 contains the final Destination Address       }
   if ( RA is     the final recipient ) { Address 3 contains the RA}
pardeepk
Frequent Visitor
Frequent Visitor
Hi Rajan,
Thanks for sharing ,wonderful information to granular analysis.
