uatukur06
Community Member
I have a question and i need a solution and expert help.
I have done a deployment which involves Security (ASA5540), Routing/voice gateway/wlc NME-AIR-WLC12-k9) and Switching (Cisco3845-ccme/k9)
Below is the list of equipment used:
1. Cisco ASA 5540 - which is connected at the edge to the ISP router
2. Core Switch WS-C4948E as core and DHCP Server for all VLANs
3. Access/Distribution Switches WS-C3560G-48PS-S connected as trunk to the core switch
4. Router/Voice Gateway/WLC Cisco3845-CCME/K9 - This is the voice gateway and also the WLC
5. Wireless APs AIR-LAP1242AG-E-K9 (12 qty)
Here is the deployment scenario:
1. G0/0 of the ASA is connected to a 7200 router from the ISP (Public IP Add)
2. G0/1 of the ASA is connected to gig 1/3 on the Core Switch on VLAN 2 which is the management VLAN (Local IP 10.1.1.2)
3. Port 3 of the Core switch is on vlan 2 connected to ASA - Management IP of Core Switch is 10.1.1.1. Core Switch is the DHCP Server for all VLANS on the network.
4. All the Access/Distribution switches are configured with IP Addresses on VLAN 2
5. Telephony Services is configured on the router and DHCP Pool for Access Points and Wireless Clients is running on the router.
6. Two DHCP pools were created on the router for APs and Wireless Clients.
7. G0/0 of the router is configured on the same network that issues dhcp ip to the AP and is connected to gig 1/1 on the core switch
8  G0/1 of the router is configured as the voice port for the IP Telephony Services and is connected to G 1/2 on the core switch
1. Clients receiving DHCP IP on the Core Switch can communicate with all vlans and can browse to the Internet.
2. IP Telephony Services is running well.
3. Client on wireless can get IP from the DHCP on the router but cannot browse.
I have pings from the router to the core switch and firewall, but clients connected to the wireless
cannot ping other vlans on the core switch and vice versa.
The port connecting the router to the core switch is an Access Port, i have changed to to trunk but still no changes.
My biggest problem now is how to make the clients on the wireless communicate with other clients on the network and be able to browse to the Internet.
