Aaron
This is the Wireless Software Compatibility Matrix, that is supposed to be found at http://www.cisco.com/en/US/docs/wireless/controller/4400/tech_notes/Wireless_Software_Compatibility_Matrix.html, but which was inadvertently deleted.
Cisco 4400 Series Wireless LAN Controllers
Table Of Contents
Wireless Solutions Software Compatibility Matrix
Contents
Conventions
Software Release Compatibility Matrix
Mesh and Mainstream Controller Software Releases
Special Rules for Upgrading to Controller Software Release 7.0.116.0
Software Release Support for Access Points
Interoperability With Other Clients
Wireless Control System Compatibility Matrix
WCS and Navigator Compatibility
Inter-Release Controller Mobility (IRCM)
Obtaining Documentation and Submitting a Service Request
July 2011
This document describes the software compatibility matrix for the Cisco wireless devices used in a Cisco Centralized and Distributed WLAN Solution.
Contents
This document contains the following sections:
•Conventions
•Software Release Compatibility Matrix
•Mesh and Mainstream Controller Software Releases
•Wireless Control System Compatibility Matrix
•Inter-Release Controller Mobility (IRCM)
•Cisco Support Community
•Obtaining Documentation and Submitting a Service Request
Conventions
See Cisco Technical Tips Conventionsfor information about document conventions.
Table 1lists the Wireless Software compatibility matrix.
Table 1 Wireless Software Compatiblity Matrix
IOS Release
WLC
WCS
Navigator
Location
MSE
12.4(23c)JA2
7.0.116.0
7.0.172.0
1.6.172.0
NA
7.0.201.204
12.4(23c)JZ
7.0.98.218
7.0.164.3
1.6.164.3
NA
7.0.105.0
12.4(23c)JA
7.0.98.0
7.0.164.0
1.6.164.0
NA
7.0.105.0
12.4(21a)JHC
6.0.202.0
6.0.202.0
1.5.202.0
6.0.202.0
6.0.202.0
12.4(21a)JHB1
6.0.199.4
6.0.196.0
1.5.196.0
6.0.102.0
6.0.105.0
12.4(21a)JHB
6.0.199.0
6.0.196.0
1.5.196.0
6.0.102.0
6.0.105.0
12.4(21a)JHA
6.0.196.0
6.0.181.0
1.5.181.0
6.0.101.0
6.0.103.0
12.4(21a)JA2
6.0.188.0
6.0.170.0
1.5.170.0
6.0.97.0
6.0.97.0
12.4(21a)JA
6.0.182.0
6.0.132.0
1.5.132.0
6.0.75.0
6.0.75.0
12.4(18a)JA2
5.2.193.0
5.2.148.0
1.4.148.0
5.2.100.0
5.2.100.0
12.4(18a)JA1
5.2.178.0
5.2.130.0
1.4.130.0
NA
NA
12.4(18a)JA
5.2.157.0
5.2.110.0
1.4.110.0
5.2.91.0
5.2.91.0
12.4(16b)JA1
5.1.163.0
5.1.65.4
1.3.65.4
5.1.35.0
5.1.35.0
12.4(16b)JA
5.1.151.0
5.1.64.0
1.3.64.0
5.1.30.0
5.1.30.0
12.4(13d)JA1
5.0.148.2
5.0.72.0
1.2.72.0
4.0.38.0
NA
12.4(13d)JA
5.0.148.0
5.0.55.0
1.2.56.0
4.0.32.0
NA
12.4(10b)JA
4.2.61.0
4.2.62.0
1.1.62.0
3.1.35.0
NA
12.4(10b)JA1
4.2.99.0
4.2.61.11
1.1.61.11
NA
NA
12.4(10b)JA2
4.2.112.0
4.2.81.0
1.1.81.0
3.1.36.0
NA
12.4(10b)JA4
4.2.130.0 (MD)
NA
NA
NA
NA
12.4(10b)JDA
4.2.173.0 (MD)
NA
NA
NA
NA
12.4(10b)JDE
4.2.209.0
4.2.209.0
NA
NA
NA
12.4(10b)JDD
4.2.207.0 (MD)
NA
NA
NA
NA
12.4(10b)JDC
4.2.205.0 (MD)
4.2.128.0
1.1.128.0
3.1.43.0
NA
12.4(10b)JDA1
4.2.176.51
4.2.176.51M
NA
NA
NA
12.4(10b)JDD
4.2.207.54M
4.2.207.54M
NA
NA
NA
12.4(3g)JMC
4.1.192.17M
NA
NA
NA
NA
12.4(3g)JMB
4.1.191.24M
NA
NA
NA
NA
12.4(3g)JA
4.1.171.0
4.1.83.0
4.1.83.0
3.0.37.0
NA
12.4(3g)JA1
4.1.181.0
4.1.91.0
4.1.91.0
3.0.42.0
NA
12.4(3g)JA2
4.1.185.0
NA
NA
NA
NA
12.4(3g)JMA
4.0.217.204
NA
NA
NA
NA
12.3(11)JA
4.0.179.8
4.0.81.0
NA
NA
NA
NA
4.0.179.11
NA
NA
NA
NA
12.3(11)JA1
4.0.206.0
4.0.96.0
NA
NA
NA
12.3(11)JA3
4.0.217.0
4.0.97.0
NA
NA
NA
12.3(11)JX
4.0.155.0
4.0.66.0
NA
NA
NA
12.3(7)JX2
3.2.78.0
NA
NA
NA
NA
12.3(7)JX3
3.2.116.21
NA
NA
NA
NA
12.3(7)JX5
3.2.150.6
NA
NA
NA
NA
12.3(7)JX6
3.2.171.6
NA
NA
NA
NA
12.3(7)JX7
3.2.193.5
NA
NA
NA
NA
12.3(7)JX8
3.2.195.10
NA
NA
NA
NA
12.3(7)JX10
3.2.202.0
NA
NA
NA
NA
12.3(7)JX11
3.2.210.0
NA
NA
NA
NA
Table 2lists the mesh and controller software releases and the compatible access points.
Table 2 Mesh and Controller Software Releases and the Supported APs
Mesh and Controller Releases
Supported Access Points
7.0.116.0
1522, 1524PS, 1524SB, 1552E, 1552H, 1552I, 1552C, 1130, 1240, 1250, 1260, 3500e, 3500i, 1140
7.0.98.218
1522, 1524PS, 1524SB, 1130, 1240
7.0.98.0
6.0.202.0
5.2.193.0
1522, 1524PS, 1130, 1240
4.1.192.35M (Mesh Release 3)
1505, 1510, 1522, 1524PS, 1130, 1240
4.1.191.24M (Mesh Release 2)
1505, 1510, 1522 (US, Canada, and RoW), 1130, 1240
4.1.190.5 (Mesh Release 1)
1505, 1510, 1522 (US and Canada)
Note See the relevant release notes before you perform any software upgrade. The release notes are available at http://www.cisco.com/en/US/products/ps6366/prod_release_notes_list.html.
Before upgrading your controller to software release 7.0.116.0, you must comply with the following rules:
•Before you download a software image or an ER.aes file to a 2100 series controller or a controller network module, use the show memory statistics CLIcommand to see the current amount of free memory. If the controller has less than 90 MB of free memory, you need to reboot it before downloading the file.
•Before you use an AP801 series lightweight access point with controller software release 7.0.116.0, you must upgrade the software in the Cisco 860 and 880 Series Integrated Services Routers (ISRs) to Cisco IOS 12.4(22)T and the software in the Cisco 890 Series Integrated Services Router to Cisco IOS 12.4(22)YB.
•Make sure that you have a TFTP or FTP server available for the software upgrade. Keep these guidelines in mind when setting up a TFTP or FTP server:
–Controller software release 7.0.116.0 is larger than 32 MB; therefore, you must make sure that your TFTP server supports files that are larger than 32 MB. Some TFTP servers that support files of this size are tftpd and the TFTP server within the WCS. If you attempt to download the 7.0.116.0 controller software and your TFTP server does not support files of this size, the following error message appears: "TFTP failure while storing in flash."
–If you are upgrading through the service port, the TFTP or FTP server must be on the same subnet as the service port because the service port is not routable, or you must create static routes on the controller.
–If you are upgrading through the distribution system network port, the TFTP or FTP server can be on the same or a different subnet because the distribution system port is routable.
–A third-party TFTP or FTP server cannot run on the same computer as WCS because the WCS built-in TFTP or FTP server and the third-party TFTP or FTP server require the same communication port.
•You can upgrade or downgrade the controller software only between certain releases. In some instances, you must first install an intermediate release prior to upgrading to software release 7.0.116.0. Table 3shows the upgrade path that you must follow before downloading software release 7.0.116.0.
•Before you use an AP802 series lightweight access point with controller software release 7.0.116.0, you must upgrade the software in the Next Generation Cisco 880 Series Integrated Services Routers (ISRs) to Cisco IOS 151-4.M or later releases.
Table 3 Upgrade Path to Controller Software Release 7.0.116.0
Current Software Release
Upgrade Path to 7.0.116.0 Software
3.2.78.0 or later 3.2 release
Upgrade to a 4.1 release and then upgrade to 4.2.176.0 before upgrading to 7.0.116.0.
4.0.155.5 or later 4.0 release
Upgrade to 4.2.176.0 before upgrading to 7.0.116.0.
4.1.171.0 or later 4.1 release
4.1.191.xM
Upgrade to 4.1.192.35M and then to 6.0.182.0 before upgrading to 7.0.116.0.
4.1.192.22M or 4.1.192.35M
Upgrade to 6.0.182.0 before upgrading to 7.0.116.0.
4.2.130.0 or earlier 4.2 release
4.2.173.0 or later 4.2 release
You can upgrade directly to 7.0.116.0.
4.2.209.0 or later 4.2 release
5.0.148.0 or later 5.0 release
5.1.151.0 or later 5.1 release
Upgrade to a 5.2 or a 6.0 release and then upgrade to 7.0.116.0.
5.2.157.0 or later 5.2 release
6.0.188.0 or later 6.0 release
6.0.196.0 or later 6.0 release
7.0.98.0
7.0.98.218
Note When you upgrade the controller to an intermediate software release, wait until all of the access points joined to the controller are upgraded to the intermediate release before you install the 7.0.116.0 software. In large networks, it can take some time to download the software on each access point.
Note If you upgrade to the controller software release 7.0.116.0 from an earlier release, you must also upgrade WCS to 7.0.172.0 and MSE to 7.0.201.204.
•We recommend that you install the Cisco Unified Wireless Network Controller Boot Software 5.2.157.0 ER.aes file on all controller platforms. This file resolves CSCsm03461 and is necessary in order for you to view the version information for ER.aes files in the output of the show sysinfo CLI command. If you do not install this ER.aes file, your controller does not obtain the fix for this defect, and "N/A" appears in the Emergency Image Version field in the output of this command.
Note The ER .aes files are independent from the controller software files. You can run any controller software file with any ER.aes file. However, installing the latest boot software file (5.2.157.0 ER.aes) ensures that the boot software modifications in all of the previous and current boot software ER.aes files are installed.
•It is not possible to upgrade or download a new image if FIPS is enabled.
Caution If you require a downgrade from one release to another, you may lose the configuration from your current release. The workaround is to reload the previous controller configuration files saved on the backup server or to reconfigure the controller.
Table 4lists the controller software releases that support specific Cisco access points. The First Support column lists the earliest controller software release that supports the access point. For access points that are not supported in ongoing releases, the Last Support column lists the last release that supports the access point.
Table 4 Software Support for Access Points
Access Points
First Support
Last Support
1000 Series
AIR-AP1010
3.0.100.0
4.2.207.0
AIR-AP1020
3.0.100.0
4.2.207.0
AIR-AP1030
3.0.100.0
4.2.207.0
Airespace AS1200
4.0.219.0
AIR-LAP1041N
7.0.98.x
AIR-LAP1042N
7.0.98.x
1100 Series
AIR-LAP1121
4.0.155.0
AIR-LAP1131
3.1.59.24
AIR-LAP1141N
5.2.157.0
AIR-LAP1142N
5.2.157.0
1200 Series
AIR-AP1220A
3.1.59.24
AIR-AP1220B
3.1.59.24
1230 Series
AIR-AP1230A
3.1.59.24
AIR-AP1230B
3.1.59.24
AIR-LAP1231G
3.1.59.24
AIR-LAP1232AG
3.1.59.24
1240 Series
AIR-LAP1242G
3.1.59.24
AIR-LAP1242AG
3.1.59.24
1250 Series
AIR-LAP1250
4.2.61.0
AIR-LAP1252G
4.2.61.0
AIR-LAP1252AG
4.2.61.0
1260 Series
AIR-LAP1261N
7.0.116.0
AIR-LAP1262N
7.0.98.x
1300 Series
AIR-BR1310G
4.0.155.0
1400 Series
Standalone Only
N/A
3500 Series
AIR-CAP3501E
7.0.98.x
AIR-CAP3501I
7.0.98.x
AIR-CAP3502E
7.0.98.x
AIR-CAP3502I
7.0.98.x
AIR-CAP3502P
7.0.116.0
1500 Mesh Series
AIR-LAP-1505
3.1.59.24
4.2.207.54M
AIR-LAP-1510
3.1.59.24
4.2.207.54M
1520 Mesh Series
AIR-LAP1522AG
-A and N: 4.1.190.1 or 5.2 or later1
All other reg. domains: 4.1.191.24M or 5.2 or later1
AIR-LAP1522HZ
AIR-LAP1522PC
AIR-LAP1523CM
7.0.116.0 or later.
AIR-LAP1524SB
-A, C and N: 6.0 or later
All other reg. domains: 7.0.116.0 or later.
AIR-LAP1524PS
-A: 4.1.192.22M or 5.2 or later1
1550
AIR-CAP1552I-x-K9
7.0.116.0
AIR-CAP1552E-x-K9
7.0.116.0
AIR-CAP1552C-x-K9
7.0.116.0
AIR-CAP1552H-x-K9
7.0.116.0
1These access points are supported in the separate 4.1.19x.x mesh software release or with release 5.2 or later releases. These access points are not supported in the 4.2, 5.0, or 5.1 Releases.
This section describes the interoperability of the version of controller software with other client devices.
Table 5describes the configuration used for testing the clients.
Table 5 Test Bed Configuration for Interoperability
Hardware/Software Parameter
Hardware/Software Configuration Type
Release
7.0.116.0
Controller
Cisco 4400 Series Controller and Cisco 5500 Series Controller
Access points
1131, 1142, 1242, 1252, AP 3500e and AP3500i
Radio
802.11a, 802.11g, 802.11n2, 802.11n5
Security
Open, WEP, PSK (WPA and WPA2), 802.1X (WPA-TKIP and WPA2-AES) (LEAP, PEAP, EAP-FAST, EAP-TLS)
RADIUS
ACS 4.2
Type of tests
Connectivity, traffic, and roaming between two access points
Table 6lists the versions of the clients. The traffic tests included data or voice. The clients included laptops, handheld devices, phones, and printers.
Table 6 Client Type
Client Type and Name
Version
Laptop
Intel 3945/4965
11.5.1.15 or 12.4.4.5
Intel 5100/5300/6200/6300
13.1.1.1
Dell 1395/1397/Broadcom 4312HMG(L)
XP/Vista: 5.60.18.8 Win7: 5.30.21.0
Dell 1505/1510/Broadcom 4321MCAG/4322HM
5.60.18.8
Dell 1520/Broadcom 43224HMS
5.60.48.18
Atheros HB92/HB97
8.0.0.320
Atheros HB95
7.7.0.358
MacBook Pro (Broadcom)
5.10.91.26
Handheld Devices
Falcon 4200/WinCE 4.2
5.60.21
Intermec CK31/WinCE 4.2:
3.00.19.0748
Intermec CN3/Windows Mobile 5.0
3.25.15.0065
Psion 7535/WinCE 5.0
1.02.09
Psion WAP/WinCE 5.0
1.02.42
Symbol 8846/Pocket PC 4.20
2.4.2273
Symbol MC70 /Windows Mobile 5.0
3.0.0.226
Symbol MC9060/Pocket PC 4.2
3.1.7
Symbol MC9090/WinCE 5.0
3.1.7
Phones and Printers
Ascom i75
1.4.25
Nokia e61
3.0633.09.04
Spectralink 8030
104.025
Spectralink e340/PTE110
110.036/091.047/104.025
Spectralink i640/PTX110
Vocera B1000A
4.1.0.2817
Vocera B2000
4.0.0.269
Zebra QL320
HTNVK49s
Monarch 9855
3.2AB
Cisco 7921G
CP7921G-1.3.4.LOADS
Cisco 7925G
CP7925G-1.3.4.LOADS
Table 7lists the Wireless Control System (WCS) compatibility matrix.
Table 7 WCS Versions
WCS Version
Supported Controller Versions
Supported Location Server Versions
Supported MSE Versions
Release Date
Upgrade Supported From
Operating System Requirement
7.0.172.0
7.0.116.0
7.0.98.218
7.0.98.0
6.0.202.0
6.0.196.0
6.0.188.0
6.0.182.0
6.0.108.0
5.2.193.0
5.2.178.0
5.2.157.0
4.2.209.0
4.2.207.0
4.2.205.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
NA
7.0.201.204
April 2011
7.0.164.3
7.0.164.0
6.0.202.0
6.0.196.0
6.0.181.0
6.0.170.0
6.0.132.0
5.2.148.0
5.2.130.0
5.2.125.0
5.2.110.
Windows 2003 SP2 32-bit
RHEL 5.x
Windows/ RHEL on ESX 3.0.1 and above
No support for 64 bit
7.0.164.3
7.0.98.218
7.0.98.0
6.0.196.0
6.0.188.0
6.0.182.0
6.0.108.0
5.2.193.0
5.2.178.0
5.2.157.0
4.2.209.0
4.2.207.0
4.2.205.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
NA
7.0.105.0
June 2010
6.0.181.0
6.0.170.0
6.0.132.0
5.2.148.0
5.2.130.0
5.2.125.0
5.2.110.0
RHEL 5.x
7.0.164.0
7.0.98.218
7.0.98.0
6.0.196.0
6.0.188.0
6.0.182.0
6.0.108.0
5.2.193.0
5.2.178.0
5.2.157.0
4.2.209.0
4.2.207.0
4.2.205.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
NA
7.0.105.0
June 2010
6.0.181.0
6.0.170.0
6.0.132.0
5.2.148.0
5.2.130.0
5.2.125.0
5.2.110.0
RHEL 5.x
6.0.196.0
6.0.199.4
6.0.199.0 (pulled from CCO)
6.0.196.0
6.0.188.0
6.0.182.0
6.0.108.0
5.2.193.0
5.2.178.0
5.2.157.0
5.1.163.0
5.1.151.0
4.2.209.0
4.2.207.0
4.2.205.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
6.0.102.0
6.0.105.0
July 2010
6.0.181.0
6.0.170.0
6.0.132.0
5.2.148.0
5.2.130.0
5.2.125.0
5.2.110.0
5.1.65.4
5.1.64.0
4.2.128.0
4.2.110.0
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
RHEL 5.x
6.0.181.0
6.0.199.4
6.0.199.0
6.0.196.159
6.0.196.0
6.0.188.0
6.0.182.0
6.0.108.0
5.2.193.0
5.2.178.0
5.2.157.0
5.1.163.0
5.1.151.0
4.2.207.0
4.2.205.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
6.0.101.0
6.0.103.0
Feb 2010
6.0.170.0
6.0.132.0
5.2.148.0
5.2.130.0
5.2.125.0
5.2.110.0
5.1.65.4
5.1.64.0
4.2.128.0
4.2.110.0
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
RHEL 5.x
6.0.170.0
6.0.188.0
6.0.182.0
6.0.108.0
5.2.193.0
5.2.178.0
5.2.157.0
5.1.163.0
5.1.151.0
4.2.207.0
4.2.205.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
6.0.97.0
6.0.97.0
Nov 2009
6.0.132.0
5.2.148.0
5.2.130.0
5.2.125.0
5.2.110.0
5.1.65.4
5.1.64.0
4.2.128.0
4.2.110.0
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
RHEL 5.x
6.0.132.0
6.0.182.0
6.0.108.0
5.2.178.0
5.2.157.0
5.1.163.0
5.1.151.0
4.2.205.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
6.0.85.0
6.0.85.0
June 2009
5.2.130.0
5.2.125.0
5.2.110.0
5.1.65.4
5.1.64.0
4.2.128.0
4.2.110.0
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
RHEL 5.x
5.2.148.0
5.2.193.0
5.2.178.0
5.2.157.0
5.1.151.0
5.0.148.2
5.0.148.0
4.2.207.0
4.2.205.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
5.2.100.0
5.2.100.0
June 2009
5.2.130.0
5.2.125.0
5.2.110.0
5.1.65.4
5.1.64.0
5.0.72.0
5.0.56.2
5.0.56.0
4.2.128.0
4.2.110.0
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
RHEL 5.x
5.2.130.0
5.2.178.0
5.2.157.0
5.1.151.0
5.0.148.2
5.0.148.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
5.2.91.0
5.2.91.0
Feb 2009
5.2.125.0
5.2.110.0
5.1.65.4
5.1.64.0
5.0.72.0
5.0.56.2
5.0.56.0
4.2.110.0
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
RHEL 5.x
5.2.125.0 (pulled from CCO)
5.2.178.0
5.2.157.0
5.1.151.0
5.0.148.2
5.0.148.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
5.2.91.0
5.2.91.0
Feb 2009
5.2.110.0
5.1.65.4
5.1.64.0
5.0.72.0
5.0.56.2
5.0.56.0
4.2.110.0
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
RHEL 5.x
5.2.110.0
5.2.157.0
5.1.151.0
5.0.148.2
5.0.148.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
5.2.91.0
5.2.91.0
Nov 2008
5.1.64.0
5.0.72.0
5.0.56.2
5.0.56.0
4.2.110.0
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
RHEL 5.1
RHEL 5.0
5.1.65.4
5.1.163.0
5.1.151.0
5.0.148.2
5.0.148.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
5.1.35.0
5.1.35.0
Jan 2009
5.1.64.0
5.0.72.0
5.0.56.2
5.0.56.0
4.2.110.0
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
RHEL 5.x
RHEL 5.x
5.1.64.0
5.1.151.0
5.0.148.2
5.0.148.0
4.2.176.0
4.2.173.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
5.1.30.0
5.1.30.0
July 2008
5.0.56.2
5.0.56.0
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
RHEL 5.1
RHEL 5.0
5.0.72.0
5.0.148.2
5.0.148.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
4.1.185.0
4.1.171.0
4.0.38.0
Not Applicable
Aug 2008
5.0.56.2
5.0.56.0
4.2.62.11
4.2.62.0
4.1.91.0
4.1.83.0
RHEL 5.1
RHEL 5.0
5.0.56.2
5.0.148.0
4.2.61.0
4.1.x.x
4.0.33.0
Not Applicable
Apr 2008
5.0.56.0
4.2.62.11
4.2.62.0
4.1.91.0
4.1.83.0
RHEL 5.0
5.0.56.0
5.0.148.0
4.2.61.0
4.1.x.x
4.0.32.0
Not Applicable
Feb 2008
4.2.62.11
4.2.62.0
4.1.91.0
4.1.83.0
RHEL 5.0
4.2.128.0
4.2.209.0
4.2.207.0
4.2.205.0
4.2.176.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
4.1.185.0
4.1.171.0
4.0.216.0
4.0.206.0
4.0.179.11
4.0.179.8
4.0.155.0
3.1.43.0
Not Applicable
May 2009
4.2.110.0
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
4.1.91.0
4.1.83.0
4.0.100.0
4.0.97.0
4.0.96.0
4.0.87.0
4.0.81.0
4.0.66.0
RHEL 4.0
RHEL 5.0 (5.1 and later no supported)
4.2.110.0
4.2.176.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
4.1.185.0
4.1.171.0
4.0.216.0
4.0.206.0
4.0.179.11
4.0.179.8
4.0.155.0
3.1.42.0
Not Applicable
Sep 2008
4.2.97.0
4.2.81.0
4.2.62.11
4.2.62.0
4.1.91.0
4.1.83.0
4.0.100.0
4.0.97.0
4.0.96.0
4.0.87.0
4.0.81.0
4.0.66.0
RHEL 4.0
RHEL 5.0
4.2.97.0
4.2.176.0
4.2.130.0
4.2.112.0
4.2.99.0
4.2.61.0
4.1.185.0
4.1.171.0
4.0.216.0
4.0.206.0
4.0.179.11
4.0.179.8
4.0.155.0
3.1.38.0
Not Applicable
Jun 2008
4.2.81.0
4.2.62.11
4.2.62.0
4.1.91.0
4.1.83.0
4.0.100.0
4.0.97.0
4.0.96.0
4.0.87.0
4.0.81.0
4.0.66.0
RHEL 4.0
RHEL 5.0
Windows/RHEL on ESX 3.0.1 and above
4.2.81.0
4.2.99.0
4.2.61.0
4.1.185.0
4.1.171.0
4.0.216.0
4.0.206.0
4.0.179.11
4.0.179.8
4.0.155.0
3.1.36.0
Not Applicable
Mar 2008
4.2.62.11
4.2.62.0
4.1.91.0
4.1.83.0
4.0.100.0
4.0.97.0
4.0.96.0
4.0.87.0
4.0.81.0
4.0.66.0
RHEL 4.0
RHEL 5.0
4.2.62.11
4.2.61.0
4.1.185.0
4.1.171.0
4.0.216.0
4.0.206.0
4.0.179.11
4.0.179.8
4.0.155.0
3.1.35.0
Not Applicable
Jan 2008
4.2.62.0
4.1.91.0
4.1.83.0
4.0.100.0
4.0.97.0
4.0.96.0
4.0.87.0
4.0.81.0
4.0.66.0
RHEL 4.0 Update 5
4.2.62.0
4.2.61.0
4.1.185.0
4.1.171.0
4.0.216.0
4.0.206.0
4.0.179.11
4.0.179.8
4.0.155.0
3.1.35.0
Not Applicable
Nov 2007
4.1.91.0
4.1.83.0
4.0.100.0
4.0.97.0
4.0.96.0
4.0.87.0
4.0.81.0
4.0.66.0
RHEL 4.0 Update 5
Cisco WCS and Cisco WCS Navigator must be from the same release in order to be compatible (see Table 8). Although the release numbers will not be the same, you must verify whether they were part of the same release.
For example, Cisco WCS Navigator 1.0 is compatible with Cisco WCS 4.1, and Cisco WCS Navigator 1.1.x is compatible with any Cisco WCS 4.2.x.
Note When Cisco WCS Navigator is upgraded to a new version, the corresponding Cisco WCS must also be upgraded to the corresponding new version. For example, if Cisco WCS Navigator is upgraded to version 1.6, Cisco WCS must also be upgraded to the corresponding version 7.0.
Table 8 Compatiblity Matrix
Navigator Release Number
WCS Release Number
1.6.172.0
7.0.172.0
1.6.164.3
7.0.164.3
1.6.164.0
7.0.164.0 and 7.0.164.3
1.5.202.0
6.0.132.0, 6.0.181.0, and 6.0.202.0
1.5.181.0
6.0.181.0
1.5.170.0
6.0.170.0
1.5.132.0
6.0.132.0
1.4.148.0
5.2.148.0
1.4.130.0
5.2.130.0, 5.2.110.0
1.4.110.0
5.2.110.0
1.3.64.0
5.1.64.0
1.1.128.0
4.2.97.0, 4.2.81.0, 4.2.62.11, 4.2.62.0, 4.2.110.0, 4.2.128.0
1.1.110.0
1.1.97.0
1.1.62.11
4.2.62.11, 4.2.62.0
1.1.62.0
4.2.62.0
1.0.91.0
4.1.91.0, 4.1.83.0
1.0.83.0
4.1.83.0
Table 9lists the inter-release Controller Mobility (IRCM) compatibility matrix.
Table 9 Inter-Release Controller Mobility Compatiblity Matrix
CUWN Service
4.2.x.x
5.0.x.x
5.1.x.x
6.0.x.x
7.0.x.x
Layer 2 and Layer 3 Roaming
X
X
X
Guest Access/Termination
X
X
X
X
X
Rogue Detection
X
X
X
Fast Roaming (CCKM) in a mobility group
X
X
X
Location Services
X
X
X
Radio Resource Management (RRM)
X
X
X
Management Frame Protection (MFP)
X
X
X
AP Failover
X
X
X
Cisco Support Community is a forum for you to ask and answer questions, share suggestions, and collaborate with your peers. Join the forum at https://supportforums.cisco.com/index.jspa.
For information on obtaining documentation, submitting a service request, and gathering additional information, see the monthly What's New in Cisco Product Documentation, which also lists all new and revised Cisco technical documentation, at:
http://www.cisco.com/en/US/docs/general/whatsnew/whatsnew.html
Subscribe to the What's New in Cisco Product Documentation as a Really Simple Syndication (RSS) feed and set content to be delivered directly to your desktop using a reader application. The RSS feeds are a free service and Cisco currently supports RSS Version 2.0.
© 2011 Cisco Systems, Inc. All rights reserved.
