houpingping
Community Member
gohussai
Level 8
Level 8
Seems like Alias has been set.  Use the "no alias" followed by "show running-config" and same with "show run-config" .
This will remove the alias set on original commands.
NOte: If there is any issue with the command then use "no" with "?" and you will came to know the exact command.
