Javier Contreras
WLC Config Analyzer Feature Tracking
Updated: 22-April-2014
Converged Access support
IDTo do item/feature requestETAStatus
1NGWC: Add multicast/multicast config detection
AI: Seema to add more details on detection logic
3.4
2NGWC: Detect missing virtual IP address in web auth configuration
AI: Madhu to provide more details
3.4
New Checks
1Report error if more than one interface has native vlan 0, and using non-lag scenario. This is unsupported scenario for IPv6 clients3.3
New Features
Add parsing and config comparison between controllers for:
Clean Air Solution Setting
Air Quality Settings
Interference Device Settings
CleanAir ED-RRM Settings
3.4
2Flexconnect group support
Add parsing and config display for flex connect groups
3.3
3Compare vlan mappings for APs on same flex connect group3.4
4Client SNR/RSSI distribution graph3.2Implemented  SNR in beta 3.2.3
5BYOD Audit3.4Check policies under discussion/development
6Best Practices 2.0 Implementation3.2Partially implemented in 3.2.2
Cliff Campbell
Community Member
I have two feature requests:
1. 8.0 support (obviously).  Getting "parsign" (spelling error; feature request 1a? :D) errors for QinQ configuration and capwap prefer mode
2. CCA recommends AVC on a vWLC which isn't supported.  Maybe a check for this?
