Current recommended version of NFVIS running on ENCS 5400
julian.bendix
Level 3
Level 3
Hey Team!
Seems there is a brand new board here on Cisco Community
Throughout the last few years we went through a lot of versions of NFVIS .. from 3.6.x al the way up to 4.4.x so far.
We regulary perform upgrades due to hitting bugs... mostly the bugs concern connectivity of CIMC or SNMP access.
One time I thought DNAC software has issues because after upgrading from 3.9.x to 3.10.x there was a bug concerning RBAC config and the local users had to be removed and re-entered.
Which versions are you currently using out there?
Thanks and BR
Jules
Thank you for the recommendation.
Joseph84174
I also have this same question and I cannot find any proper answers on the internet and also need a solution. Works like a charm!  Emory Patient Portal
