yvivekan
hi,
I've installed Viptela CFPs and also the cisco-apicdc in my NCS packages
while started the  "ncs --with-package-reload"
getting error in start up , connection to confD refused.
==> ncs-python-vm-tailf-etsi-rel2-nfvo-nfvis.log <==
<ERROR> 28-Mar-2019::16:54:32.859 tailf-etsi-rel2-nfvo-nfvis ComponentThread:tailf_etsi_rel2_nfvo_nfvis_init: - Traceback (most recent call last):
File "/home/nso/nso-4.7/src/ncs/pyapi/ncs_pyvm/ncsthreads.py", line 173, in run
self.main._run()
File "/home/nso/nso-4.7/src/ncs/pyapi/ncs/application.py", line 214, in _run
with maapi.Maapi(load_schemas=True):
File "/home/nso/nso-4.7/src/ncs/pyapi/ncs/maapi.py", line 181, in __init__
self.msock = connect(ip, port, path)
File "/home/nso/nso-4.7/src/ncs/pyapi/ncs/maapi.py", line 97, in connect
_tm.maapi.connect(msock, ip, port)
Error: system call failed (24): Failed to connect to ConfD: Connection refused
any one come accross ConfD issue?
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
