Add a commit comment from python code
I'm wondering how can I add a comment to a commit launched from python code using MAAPI API.
I found that there is a function called
int maapi_set_comment(int sock, int thandle, const char *comment)
but I didn't figure out how can I use it.
Thanks in advance,
Nabsch
Hello Alaeddine ,
Here an example where i create a device-group then i set  a comment
with ncs.maapi.Maapi() as m:
    with ncs.maapi.Session(m, 'admin', 'test_context'):
        with m.start_write_trans() as trans:
            root = ncs.maagic.get_root(trans)
            root.ncs__devices.device_group.create("test-python512115")
            trans.set_comment("commit via PYTHON1")
            trans.apply()
You can verify the comment in cli
admin@ncs# show configuration commit list
2022-01-26 18:15:19
SNo.  ID       User       Client      Time Stamp          Label       Comment
10017 10017    admin      system      2022-01-26 18:06:46             commit via PYTHON1
5 Replies 5
Nabsch
Hello Alaeddine ,
            trans.apply()
2022-01-26 18:15:19
Thank you very much for your reply.
fracjackmac
Level 5
Level 5
Hello @AlaeddineJebnoun90723 and @Nabsch,
Would you please provide a link to the MAAPI API?  I'm not familiar with this API and am interested in learning more about it.
Thanks!
Hello ,
Here  a Link to documentation  but you should also have a look to the source code.
Thank you @Nabsch.
