Addloadpath error
RichardD2
Level 4
Level 4
Running 6.1.11.2 and can't connect to ncs or run ncs_cli.
Am getting the following error in devel.log
devel-cdb Get argument failed with flag: addloadpath
Can someone please share how I can troubleshoot this and where I should be looking.
thanks
RichardD2
Level 4
Level 4
Looks like there was an error in the Makefile with a reference to a NED that's no longer used. Problem solved.
rogaglia
Can you add the exact command you are running?
In man page, you can see that "--addloadpath Dir" should be used when starting NSO only.
RichardD2
Level 4
Level 4
I am getting the same error in devel logs. Can you please let me know how did you debug this issue?
Aparna
RichardD2
Level 4
Level 4
Just looked at devel.log when NSO was starting up, to see the error message
