Centos NSO process
spudukko
NSO process spawning on Centos takes a lot of time and the process of detecting how the startup coming along is difficult.  Is there a way to understand nso process on centos.
1) Ports binding to be freed
2) Also the error status have to monitored from system journal
even after doing a systemctl daemon-reload
 For example see the error below
Restarting ncs (via systemctl):  Job for ncs.service failed because the control process exited with error code. See "systemctl status ncs.service" and "journalctl -xe" for details.
Jan Lindblad
Are you setting up a production NSO system? If not, I would strongly recommend making a "local install" instead.
Does your installation work, just slowly, or do you never get NSO up and running in your environment?
Do you have a lot of data in your database? If not, NSO should start in a few seconds.
Ports used by NSO are configured in the ncs.conf file. Try man ncs.conf to see what's available.
Jan Lindblad
I am testing on a system install and ncs starting process is fine with ubuntu but with centos i am unable to consistently understand nso vm is started or not as  it fails and asks to check system journal.
It is after calling /etc/init.d/ncs restart the service fails after sometime and asks to contact system journal.
so the ncs start process in ubuntu  is fine but with  centos i have issues .
I am using centos, I am not facing the same issue. Can you please provide the following command outputs to check about it.
journalctl -xe
