CLI pipe to save to a file
sm000x
I want to save a cli output to a file, however, cli does not allow me to save to a directory other than where I starts the ncs_cli.
For example, if I am in /root and start ncs_cli and I want to save cli output
to /tmp:
[root@mtnj06 ~]# ncs_cli -u admin
admin@ncs> show configuration devices device lab7smf | save /tmp/xyz100
syntax error: access denied
[error][2023-10-05 16:11:04]
I can only save it to the directory where I start the ncs_cli:
sm000x@ncs> show configuration devices device lab7smf | save xyz100
[ok][2023-10-05 16:11:38]
sm000x@ncs> exit
I probably did something wrong.
Does anyone have same issue?
THX
sm000x
18 Replies 18
Hi, Cohult:
Thank you for the reply. I will try your suggestion to use ncs_load.
As for ncs_cli save to some directory, I have an example here:
(1) I am user sm000x, I have access right to /tmp:
[sm000x@mtnjdslncs06 ~]$ cd /tmp
[sm000x@mtnjdslncs06 tmp]$ echo xyz > /tmp/xyz
(2) Now I start ncs_cli as a root under /root directory(folder)
[sm000x@mtnjdslncs06 root]$ su - root
Password:
Last login: Thu Nov 23 12:28:40 EST 2023 from attapkzupuw0wen.itservices.sbc.com on pts/2
[root@mtnjdslncs06 ~]# ncs_cli -u sm000x
User sm000x last logged in 2023-11-23T17:32:22.927493+00:00, to mtnjdslncs06, from 135.91.110.32 using cli-ssh
sm000x connected from 127.0.0.1 using console on mtnjdslncs06
sm000x@ncs> show configuration devices global-settings | save /tmp/global-settings.xml
[error][2023-11-23 12:40:37]
sm000x@ncs>
I got access denied error.
The ncs is started as root, ncs_cli is started as sm000x which has access permission on /tmp, but it still returns access denied.
THX
sm000x
cohult
You can use, for example, the process status Linux command to determine if NSO was started from a non-root user. Example:
Started by the 'root' user:
ps -C ncs.smp uc
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 640 16.4 70.8 10351564 5697440 ? Ssl 09:33 70:51 ncs.smp
Started by the non-root 'admin' user:
# ps -C ncs.smp uc
admin 644 14.5 18.5 5604616 1495112 ? Ssl 07:53 11:36 ncs.smp
cohult
Also, make sure you have 'restricted-file-access' in ncs.conf set to 'false'. However, be mindful of the implications where CLI users will be less restricted. See the ncs.conf(5) man page for details on the restricted-file-access setting.
<cli>
    <enabled>true</enabled>
    <restricted-file-access>false</restricted-file-access>
</cli>
Note that the default ncs.conf for an NSO system installation has restricted-file-access set to true.
Hi, Cohult:
Thank you so much. Somehow my system-installation has
true
I changed to false and it is working now. Now NCS is able to access to any directories as long as the login user has the permission.
This is very helpful information.
THX
sm000x
