Couldn't able to print NSO variables or objects
kiran kotari
In [29]: list(root.kicker__kickers.data_kicker)
Error Traceback (most recent call last)
<ipython-input-29-896aaac1edfe> in <module>
----> 1 list(root.kicker__kickers.data_kicker)
/opt/ncs/current/src/ncs/pyapi/ncs/maagic.py in __len__(self)
1072 """
1073 if self._backend:
-> 1074 return self._backend._num_instances(self._path)
1075 else:
1076 return len(self._cache)
/opt/ncs/current/src/ncs/pyapi/ncs/maagic.py in _num_instances(self, path)
131
132 def _num_instances(self, path):
--> 133 return self.num_instances(path)
134
135 def _cursor(self, path, enum_cs_nodes, want_values,
/opt/ncs/current/src/ncs/pyapi/ncs/maapi.py in proxy(self2, *args, **kwargs)
1202 else:
1203 real = getattr(_tm.maapi, name)
-> 1204 return real(self2.maapi.msock, self2.th, *args, **kwargs)
1205 setattr(Transaction, name, proxy)
1206 return getattr(self, name)
Error: system call failed (24): Failed to write 54 bytes to ConfD: Bad file descriptor
kiran kotari
Looks like the transaction closed, and you are trying to fetch something from CDB after the transaction is closed.
kiran kotari
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
