deep-check-sync outformat parameter in REST AP
previousqna
Level 5
Level 5
Hi Experts
We want to use REST API to get the result of below cli command
admin@ncs(config)# l3vpn-svc sites site coke-beijing deep-check-sync outformat cli
the l3vpn-svc is a service located under root.
How can I pass the parameter outformat in URL?
I have tried below url, but it gives an error.
http://{{ip}}:{{nso-port}}/api/config/l3vpn-svc/sites/site/pepsi-b/_operations/deep-check-sync?outformat=cli
Thanks.
8 Replies 8
previousqna
Level 5
Level 5
Try this:
http://{{ip}}:{{nso-port}}/api/running/l3vpn-svc/sites/site/coke-beijing/_operations/deep-check-sync?outformat=cli
I tried your url, but still got the error.
POST http://{{ip}}:{{nso-port}}/api/running/l3vpn-svc/sites/site/coke-beijing/_operations/deep-check-sync?outformat=cli
  "errors": {
    "error": [
        "error-message": "invalid query parameter: outformat",
        "error-tag": "malformed-message"
The easiest way is to obtain the path by GET.
For example, I can get the correct path as following:
$ curl -u admin:admin http://localhost:8080/api/running/services?deep | grep deep
    <deep-check-sync>/api/running/services/bgpmgr:bgpmgr/test/_operations/deep-check-sync</deep-check-sync>
Just copy and paste the path, then it should work.
$ curl -u admin:admin http://localhost:8080/api/running/services/bgpmgr:bgpmgr/test/_operations/deep-check-sync -X POST <output xmlns='http://example.com/bgpmgr'>
<sync-result>
<local-node>
<in-sync>true</in-sync>
</local-node>
</sync-result>
</output>
I gave him the correct URL for deep-check-sync, but you added a nice piece to explains how to best get this URL
I believe what he is failing on is that he also wants to add “?outformat=cli” to the end of the call..
I haven’t seen this work from curl…
On NSO…
admin@ncs% request services secPythonTempl1 FOOBAR deep-check-sync outformat
Possible completions:
  boolean - Returns if the service is in sync or not.
  cli     - The CLI config that would have to be applied to the device(s) in order for the service to
            become in sync with the network.
  xml     - The XML (NETCONF format) that would have to be applied to the device(s) in order for the
            service to become in sync with the network.
admin@ncs% request services secPythonTempl1 FOOBAR deep-check-sync outformat cli
cli {
    local-node {
        data
[ok][2017-02-13 09:07:01]
[edit]
admin@ncs%
On Mac…
Linux$ curl -X POST -u admin:admin http://localhost:8080/api/running/services/service:secPythonTempl1/FOOBAR/_operations/deep-check-sync
<output xmlns='http://example.com/service'>
  <sync-result>
    <local-node>
    </local-node>
  </sync-result>
</output>
Linux$ curl -X POST -u admin:admin http://localhost:8080/api/running/services/service:secPythonTempl1/FOOBAR/_operations/deep-check-sync?outformat=cli
<errors xmlns="http://tail-f.com/ns/tailf-rest-error">
  <error>
    <error-tag>malformed-message</error-tag>
    <error-message>invalid query parameter: outformat</error-message>
  </error>
</errors>
Linux$
Its an action, and you need to give it in the payload.
Check $NCS_DIR/src/ncs/yang/tailf-ncs-services.yang
$curl ... -d '{"input":{"outformat":"cli"}} -H "Content-type: application/vnd.yang.operation+json"
$curl ... -d '{"input":{"outformat":"xml"}} -H "Content-type: application/vnd.yang.operation+json"
$curl ... -d '{"input":{"outformat":"boolean"}} -H "Content-type: application/vnd.yang.operation+json"
Sorry [NAME] that I missed that point.
Your URL was correct and the problem was "?outformat=cli".
Thanks [NAME] for additional info.
I confirmed it works!
test@debian:~$ curl -u admin:admin http://127.0.0.1:8080/api/running/services/bgpmgr:bgpmgr/test/_operations/deep-check-sync -X POST -H "Content-type:application/vnd.yang.operation+json" -d '{"input":{"outformat":"boolean"}}'
  "bgpmgr:output": {
    "sync-result": {
      "local-node": {
        "in-sync": false
test@debian:~$ curl -u admin:admin http://127.0.0.1:8080/api/running/services/bgpmgr:bgpmgr/test/_operations/deep-check-sync -X POST -H "Content-type:application/vnd.yang.operation+json" -d '{"input":{"outformat":"cli"}}'
  "bgpmgr:output": {
    "cli": {
      "local-node": {
        "data": " devices {\n     device R1 {\n         config {\n             ios:router {\n                 bgp 65001 {\n+                    neighbor 10.12.0.2 {\n+                        remote-as 65002;\n+                    }\n                     address-family {\n                         ipv4 unicast {\n+                            neighbor 10.12.0.2 {\n+                                activate;\n+                            }\n                         }\n                     }\n                 }\n             }\n         }\n     }\n }\n"
test@debian:~$ curl -u admin:admin http://127.0.0.1:8080/api/running/services/bgpmgr:bgpmgr/test/_operations/deep-check-sync -X POST -H "Content-type:application/vnd.yang.operation+json" -d '{"input":{"outformat":"xml"}}'
  "bgpmgr:output": {
    "result-xml": {
      "local-node": {
        "data": "<devices xmlns=\"http://tail-f.com/ns/ncs\">\n  <device>\n    <name>R1</name>\n    <config>\n      <router xmlns=\"urn:ios\">\n        <bgp>\n          <as-no>65001</as-no>\n          <neighbor>\n            <id>10.12.0.2</id>\n            <remote-as>65002</remote-as>\n          </neighbor>\n          <address-family>\n            <ipv4>\n              <af>unicast</af>\n              <neighbor>\n                <id>10.12.0.2</id>\n                <activate/>\n              </neighbor>\n            </ipv4>\n          </address-family>\n        </bgp>\n      </router>\n    </config>\n  </device>\n</devices>\n"
test@debian:~$
Great thanks for all of your help. It works now.
brillant! thanks!
perfect!
He should have what he needs now
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
