default sub-statement for leaf-list in yang v1.1 doesnt work
momeirz
Hello All,
i have set a default value for a leaf-list using yang version 1.1. The assigned default value appears by pressing info button in NSO GUI but the leaf-list data shows nothing. I have tried to access the leaf-list using ncs.magic function but the list returns empty as well. Is there any way to access this default value store in cdb? And why this is happening, am I missing something?
the yang model example:
module pe-interface {
namespace "http://example.com/pe-interface";
prefix pe-interface;
yang-version 1.1;
import ietf-inet-types {
prefix inet;
import tailf-common {
prefix tailf;
import tailf-ncs {
prefix ncs;
description
"PE Port Turnup Service";
revision 2023-11-01 {
description
"Initial revision.";
list ar-ftu-mgmt {
description
"This is an RFS skeleton service";
uses ncs:service-data;
ncs:servicepoint pe-interface-servicepoint;
key "ar-name";
leaf ar-name {
tailf:info "Device Name of AR to be connected to PE";
tailf:cli-allow-range;
type string;
container service {
leaf-list dhcp-server {
tailf:info "DHCP Server IP-address";
type inet:ipv4-address;
default 10.1.90.31;
divitgupta
looks all ok
snovello
You should open a TAC case for changing the behavior of the maagic API.
Hi snovello, a case has been already opened and I will update once I get an answer.
