Error exporting development NED
martin.gysi
Frequent Visitor
Frequent Visitor
I'm trying to build a netconf NED with a netsim directory, so instead of using the normal build-ned command, I would like to use make-development-ned.
It fails with
admin@ncs# netconf-ned-builder project ngbac-mini 2.0 make-development-ned in-directory <target-dir>
Error: Error exporting development NED to the target directory: Missing permission for the file or one of its parents.
admin@ncs#
no matter what target directory I'm specifying. File permissions of the target directory are ok, and building a normal NED (build-ned command) also works. Any ideas?
rogaglia
I had this problem too. The issue is that you are login to NSO as "admin". Try to login with the user that has the permissions in the folder or using "ncs_cli -u username".
