Error when doing sync from
RichardD2
Level 4
Level 4
We get the following error intermittently as nso starts (running ver5.5)
Any ideas on why?
nso-devel ncs[900]: webui 127.0.0.1 - admin [09/Feb/2021:22:06:32 +0000] "POST /restconf/data/tailf-ncs:devices/device=iosxr-r0/sync-from HTTP/1.1" 200 76 "-" "curl/7.64.0"
=ERROR REPORT==== 9-Feb-2021::22:06:32.376601 ===
Yaws process died: {{badmatch,{error,closed}},
                    [{yaws,setopts,3,[{file,"yaws.erl"},{line,2681}]},
                     {yaws,http_recv_request,2,
                           [{file,"yaws.erl"},{line,2703}]},
                     {yaws,do_http_get_headers,2,
                           [{file,"yaws.erl"},{line,2684}]},
                     {yaws_server,aloop,4,
                                  [{file,"yaws_server.erl"},{line,1250}]},
                     {yaws_server,acceptor0,2,
                                  [{file,"yaws_server.erl"},{line,1133}]},
                     {proc_lib,init_p_do_apply,3,
                               [{file,"proc_lib.erl"},{line,249}]}]}
rogaglia
sounds like something that you need to report to the Cisco TAC.
ttornkvi
What is the boolean 'webui/transport/ssl/keepalive' config parameter set to?
RichardD2
Level 4
Level 4
Hi @ttornkvi
Looks like we don't have that setting in use. Current ncs.conf looks like this:
<webui>
    <enabled>true</enabled>
    <transport>
      <tcp>
        <ip>0.0.0.0</ip>
        <port>8080</port>
      </tcp>
      <ssl>
        <enabled>false</enabled>
        <ip>0.0.0.0</ip>
        <port>8888</port>
        <key-file>${NCS_DIR}/var/ncs/webui/cert/host.key</key-file>
        <cert-file>${NCS_DIR}/var/ncs/webui/cert/host.cert</cert-file>
      </ssl>
    </transport>
