05-09-2017 07:39 AM - edited 03-01-2019 03:48 AM
All ,
I believe this question was asked/answered a couple weeks back.
I’m unable to locate the thread.
I’m looking for a sample REST call (via CURL or python request) to sample live-status info from an IOS device.
In my specific case , I just need to get a “Show IP route”
Also, is it possible to have it rendered as json ? or is that dependent on the capabilities of the device being queried?
05-09-2017 07:39 AM
Following is an example I tested in my lab.
test@test-mint ~ $ cat body.txt
"show":
"args":"users"
test@test-mint ~ $ curl -i -u admin:admin -X POST -T body.txt http://127.0.0.1:8080/api/operational/devices/device/R1/live-status/ios-stats:exec/_operations/show -H "Content-Type:application/vnd.yang.operation+json"
HTTP/1.1 100 Continue
Server:
Allow: GET, POST, OPTIONS, HEAD
Content-Length: 0
HTTP/1.1 200 OK
Server:
Date: Tue, 13 Dec 2016 02:29:10 GMT
Cache-Control: private, no-cache, must-revalidate, proxy-revalidate
Content-Length: 264
Content-Type: application/vnd.yang.operation+json
Vary: Accept-Encoding
Pragma: no-cache
"output": {
"result": "\r\n Line User Host(s) Idle Location\r\n* 2 vty 0 cisco idle 00:00:00 10.1.1.1\r\n\r\n Interface User Mode Idle Peer Address\r\n\r\nR1#"
test@test-mint ~ $
Hope this helps.
05-09-2017 07:39 AM
I believe following is exactly what you are looking for.
"show":
"args":"ip",
"args":"route"
test@test-mint ~ $ curl -u admin:admin -X POST -T body.txt http://127.0.0.1:8080/api/operational/devices/device/R1/live-status/ios-stats:exec/_operations/show -H "Content-Type:application/vnd.yang.operation+json"
"tailf-ned-cisco-ios-stats:output": {
"result": "\r\nCodes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP\r\n D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area \r\n N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2\r\n E1 - OSPF external type 1, E2 - OSPF external type 2\r\n i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2\r\n ia - IS-IS inter area, * - candidate default, U - per-user static route\r\n o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP\r\n a - application route\r\n + - replicated route, % - next hop override\r\n\r\nGateway of last resort is not set\r\n\r\n 1.0.0.0/32 is subnetted, 1 subnets\r\nC 1.1.1.1 is directly connected, Loopback0\r\n 10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks\r\nC 10.1.1.0/24 is directly connected, Ethernet0/0\r\nL 10.1.1.2/32 is directly connected, Ethernet0/0\r\nC 10.12.0.0/24 is directly connected, Ethernet0/1\r\nL 10.12.0.1/32 is directly connected, Ethernet0/1\r\nC 10.13.0.0/24 is directly connected, Ethernet0/2\r\nL 10.13.0.1/32 is directly connected, Ethernet0/2\r\nR1#"
test@test-mint ~ $
