Foreach in own tag fails while in-tag doesn't
u.avsec
I stumbled into a situation I can't explain to myself:
<?foreach {/ce-pe-port/static/customer-routes}?>
    <ip-route-forwarding-list>
        <prefix>{customer-prefix}</prefix>
        <mask>{customer-prefix-mask}</mask>
        <forwarding-address>{customer-prefix-nh}</forwarding-address>
    </ip-route-forwarding-list>
<?end?>
This fails on packages reload with `Invalid parameters for processing instruction foreach`.
This on the other hand:
<ip-route-forwarding-list foreach="{/ce-pe-port/static/customer-routes}">
Works just fine.
Model in question is `/container/container/list`. Between the two containers there is a choice and case and the list has a 3 part combined key of "customer-prefix*" nodes seen in the example.
I'm really curious what is going on here. NSO version is 5.8.7.
hazad
What does your yang models look like? I don't get the error when I use the following template:
<config-template xmlns="http://tail-f.com/ns/config/1.0" servicepoint="template-service-servicepoint">
  <test xmlns="http://com/example/templateservice">
  <?end?>
  </test>
</config-template>
 And the following yang:
container test {
    list ip-route-forwarding-list {
      key "prefix mask forwarding-address";
      leaf prefix {
        type string;
      leaf mask {
        type string;
      leaf forwarding-address {
        type string;
  list template-service {
    key name;
    leaf name {
      type string;
    container ce-pe-port {
      container static {
        list customer-routes {
          key "customer-prefix customer-prefix-mask customer-prefix-nh";
          leaf customer-prefix {
            type string;
          leaf customer-prefix-mask {
            type string;
          leaf customer-prefix-nh {
            type string;
    uses ncs:service-data;
    ncs:servicepoint template-service-servicepoint;
The template works as expected:
admin@ncs% commit dry-run
cli {
    local-node {
        data  test {
             +    ip-route-forwarding-list a b c {
             +    ip-route-forwarding-list d e f {
             +template-service test {
             +    ce-pe-port {
             +        static {
             +            customer-routes a b c;
             +            customer-routes d e f;
Hey,
thanks for trying to look into this.
A string of things happened in an interesting way:
Unfortunately there was a typo in the templates; it is not ce-pe-port but ce-pe-prot in the actual model.
Why stuff above works partially is interesting though. The stand-alone foreach is evaluated by the NSO while the in-tag foreach isn't. The xpath was wrong in both cases but packages reload failed only in first case.
Now, the reason I didn't spot the prot/port typo initially is due to the fact that the NSO actually loops without the need for the foreach in this case. So it went like this:
  1. Trying stand-alone foreach -> package reload fails
  2. Trying same faulty xpath with in-tag foreach -> package reload succeeds
  3. Run test instance -> configuration is actually generated
    1. Foreach actually failed because of faulty xpath
    2. NSO looped through the list data automatically anyway based on the xpath in <prefix></prefix>
