how to re-deploy with commit params from python
erdemk
Level 3
Level 3
Hi all,
Could you help me on the following .. in short, how can i do re-deploy with commit params from python ..
i can commit a service with commit params from cli and python with success. for example :
from cli :
dd-rfs d1
commit commit-queue bypass
and from python :
with ncs.maapi.single_write_trans('admin', 'python', groups=['ncsadmin']) as t:
    root = ncs.maagic.get_root(t)
    root.dd_rfs__dd_rfs.create('d1')
    cp = ncs.maapi.CommitParams()
    cp.commit_queue_bypass()
    cp.no_networking()
    rr = t.apply_params(True, cp)
on the other hand, for re-deploy, i can re-deploy the service with commit params successfully from cli :
dd-rfs d1 re-deploy commit-queue { bypass }
but trying to do the same from python doesn't work :
    root.dd_rfs__dd_rfs['d1'].re_deploy()
how can i do re-deploy from python ?
Thanks and regards.
huayyang
having the same name "dry-run", it's an action input parameter to action re-deploy, not a commit parameter, so you need to do something like this:
service_instance = ncs.maagic.get_node(t, PATH_TO_YOUR_SERVICE_INSTANCE)
action = service_instance.re_deploy
action_p = action.dry_run.create()
action(action_p)
huayyang
action(action_p)
this is a working copy of bypassing a commit-queue.
instance = ncs.maagic.get_node(t, PATH_TO_YOUR_SERVICE_INSTANCE)]
inputs = instance.re_deploy.get_input()
inputs.commit_queue.create().bypass.create()
inputs.no_networking.create()
instance.re_deploy(inputs)
johnnyb
Community Member
how do you change commit_queue parameters?
Like set async, and atomic = false?
Then re_deploy
take a look at our updated document: https://cisco-tailf.gitbook.io/nso-docs/guides/development/core-concepts/api-overview/python-api-overview#maagic-api
that together with the model of the action(service re-deploy action is defined in tailf-ncs-services.yang while the ncs-commit-queue grouping in tailf-ncs-devices.yang ) should give you the answer
