NCS Smart Licensing Java VM failed starting ? Need help
soubeher
Starting to listen for CLI SSH on 0.0.0.0:2024
<INFO> 1-Aug-2019::11:01:49.719 soubeher-VirtualBox ncs[6529]: - Starting the NCS Smart Licensing Java VM
<INFO> 1-Aug-2019::11:01:49.764 soubeher-VirtualBox ncs[6529]: - NCS started vsn: 4.7.2.1
<INFO> 1-Aug-2019::11:01:50.059 soubeher-VirtualBox ncs[6529]: - The NCS Smart Licensing Java VM terminated
<INFO> 1-Aug-2019::11:01:50.242 soubeher-VirtualBox ncs[6529]: - Starting the NCS Smart Licensing Java VM
<INFO> 1-Aug-2019::11:01:50.586 soubeher-VirtualBox ncs[6529]: - The NCS Smart Licensing Java VM failed starting - needs to be corrected!
<INFO> 1-Aug-2019::11:11:50.589 soubeher-VirtualBox ncs[6529]: - The NCS Smart Licensing Java VM terminated
<INFO> 1-Aug-2019::11:11:50.851 soubeher-VirtualBox ncs[6529]: - Starting the NCS Smart Licensing Java VM
<INFO> 1-Aug-2019::11:11:51.092 soubeher-VirtualBox ncs[6529]: - The NCS Smart Licensing Java VM failed starting - needs to be corrected!
admin connected from 127.0.0.1 using console on soubeher-VirtualBox
admin@ncs# show license all
Error: License Agent not ready.  Please try again.
What are the steps to follow ?
uavsec001
Level 3
Level 3
Hey,
depends on what you want to do... if you want to use this NSO just for development (judging form soubeher-VirtualBox), then you don't have to do anything really, your NSO will be running just fine (it used to be a 90 day trail period, now it might be different considering the thing is publicly available to anyone).
Production on the other hand... you would want to get your Smart Software Manager satellite and all that similar jazz going.
