NED-ID old style syntax
ngrgur
I am planning an upgrade of NSO platform from 4.7 to 5.3.
Newer version of NSO is interpreting NED as: device.device_type.cli.ned_id = cisco-ios-cli-6.33:cisco-ios-cli-6.33
However we have a lot of packages and services developed with check for old style NED id:
device.device_type.cli.ned_id = 'ios-id:cisco-ios'
(without specified version).
Is there a way to represent old style NED id on NSO 5.3?
Here is the reference from the NED yang file (tailf-ned-cisco-ios-meta.yang
augment "/ncs:devices/ncs:device/ncs:ned-settings" {
// Different 'when' expressions used when building for NSOs with and without CDM support.
// The NED build system will automatically 'uncomment' the right one.
// CDM style syntax
//when "derived-from(../ncs:device-type/ncs:cli/ncs:ned-id,'family:cisco-ios-cli')";
// Old style syntax:
//when "../ncs:device-type/ncs:cli/ncs:ned-id = 'ios-id:cisco-ios'";
uses cisco-ios-ned-settings-grouping;
Nikola
hniska
you could use the xpath function derived-from, something like
import _ncs
_ncs.maapi.xpath_eval_expr(m.msock, trans.th, 'derived-from-or-self(/ncs:devices/device[name="ce0"]/device-type/cli/ned-id,"cisco-ios-cli:cisco-ios-cli")', None,'')
