NED Upgrade Using newer version than NSO
tsiemers1
Does it matter if you use a NED that is ahead of your NSO version by a patch release?
Example
NSO Version: 5.5.4.1
NED Version: 5.5.6
Cisco NSO Cisco IOS XR NED
ncs-5.5.6-cisco-iosxr-7.39.15.signed.bin
rogaglia
In 99.999% of the cases no.
In very specific cases, the patch solves a critical bug that the NED needs for your usecase or to work. That would be well documented in the NED CHANGE log and could be that the NED sets it as "min-version" in its package-meta-data.xml document.
For example, the current cisco-ios NED has the following restrictions (all for very old versions). Which means that the NED could not be used with (for example) 4.7.2 NSO version.
<ncs-min-version>4.4.5</ncs-min-version>
<ncs-min-version>4.5.1.1</ncs-min-version>
<ncs-min-version>4.6.3</ncs-min-version>
<ncs-min-version>4.7.3.1</ncs-min-version>
rogaglia
Perfect. I forgot about the package-meta-data file.
show packages package cisco-iosxr-cli-7.39 ncs-min-version
ncs-min-version [ 4.4.2 4.7.3 ]
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
