Need help on generic Ned with Netconf Call Home
JennyW
With netconf call home, netconf client uses ssh client protocol to establish connection with a managed device. The NSO 5.8 user guide states "SSH connection is established, and NSO is enabled to communicate with the device. " Does this mean the authentication is done outside of Ned? If that's the case, who creates NedWorker, Ned or NSO?
Alexander Stevenson
Hello @JennyW,
I found a couple of discussions on this topic with several links in them to more info.
Create your first Generic REST NED
Creating a GENERIC NED v 1.0
I hope this is helpful.
Alexander Stevenson
Hello @JennyW,
Thank you, I have gone through these discussions a couple of times, they did help a bit but not that much because the example doesn't use netconf call home. I have figured out most of the part how to do it.
