NSO add device python API
mhemmatp
Hello all,
I am trying to add NETCONF device to NSO through python API as follows:
import ncs;
with ncs.maapi.single_write_trans('admin', 'python', groups=['ncsadmin']) as t:
root = ncs.maagic.get_root(t)
root.devices.device.create('test')
root.devices.device['test'].address = '127.0.0.1'
root.devices.device['test'].port = 22
root.devices.device['test'].device_type.cli.create()
root.devices.device['test'].device_type.cli.ned_id = 'netconf'
root.devices.device['test'].device_type.cli.protocol = 'ssh'
root.devices.device['test'].authgroup = 'authtest'
root.devices.device['test'].state.admin_state = 'unlocked'
But I receive the following error:
File "src/ncs/pyapi/ncs/maagic.py", line 471, in __setattr__
child.set_value(value)
File "src/ncs/pyapi/ncs/maagic.py", line 939, in set_value
value = _python_to_yang(value, self._cs_node)
File "src/ncs/pyapi/ncs/maagic.py", line 1927, in _python_to_yang
return _tm.Value.str2val(str(value), cs_node)
_ncs.error.Error: item has a bad/wrong type (5): Invalid string for type
what is the problem of my code?
This python code will add a netconf device to the device tree:
In [15]: with ncs.maapi.Maapi() as m:
...:           with ncs.maapi.Session(m, 'admin', 'python'):
...:              with m.start_write_trans() as t:
...:                  root = ncs.maagic.get_root(t)
...:                  newdev = root.devices.device.create('test-dev')
...:                  newdev.address = '127.0.0.1'
...:                  newdev.port = 830
...:                  newdev.authgroup = 'default'
...:                  dev_type = newdev.device_type.netconf.create()
...:                  dev_type.ned_id = 'netconf'
...:                  print (dev_type)
...:                  newdev.state.admin_state = 'southbound-locked'
...:                  t.apply()
netconf
admin@ncs% show devices device test-dev
address 127.0.0.1;
port 830;
authgroup default;
device-type {
      netconf {
           ned-id netconf;
state {
      admin-state southbound-locked;
12 Replies 12
protocol will = netconf or ssh
ned_id should be cisco-ios or nx or xr etc etc
Still it does not work. My goal is to add a netconf device do you think my syntax is OK:
root.devices.device['test'].device_type.cli.ned_id = ...
device_type.cli does not indicate I am adding a cli device?
what is the actual device ?
and do you have a NED for it
eg if i wanted to add an IOS router i would use the cisco-ios NED that ned can communicate with the device in several ways eg SSH or Netconf
It is worth noting that netconf and ssh are not interchangeable here. Either you want a CLI ned that can communicate over a protocol like ssh or telnet or you want a netconf ned (that can also communicate over ssh). So when it says .cli you are in the cli-ned specific part of the config.
So, as I understood the cli does not indicate I am adding a cli device it can be used to add a netconf device ad well. Am I right?
No. CLI definitely indicates that you are adding a CLI device. To add a netconf device, use the netconf sub-tree. That is device_type.netconf instead of device_type.cli.
Thanks for the reply. I set the netconf.ned_id to 'netconf' and I removed the netconf.protocol. Still I have the following ERR:
File "src/ncs/pyapi/ncs/maapi.py", line 1005, in apply
self.maapi.apply_trans_flags(self.th, keep_open, flags)
File "src/ncs/pyapi/ncs/maapi.py", line 254, in proxy
return real(self2.msock, *args, **kwargs)
File "/usr/lib/python2.7/socket.py", line 228, in meth
return getattr(self._sock,name)(*args)
File "/usr/lib/python2.7/socket.py", line 174, in _dummy
raise error(EBADF, 'Bad file descriptor')
socket.error: [Errno 9] Bad file descriptor
That is an unrelated error. Might be related to reusing a socket after closing it or overwriting a handle or something.
I have a host with NETCONF server. I created already a NED for it in the NSO.
...:                  t.apply()
netconf
address 127.0.0.1;
port 830;
authgroup default;
device-type {
      netconf {
           ned-id netconf;
state {
Thanks. It worked for me!
nisheeth
I have multiple neds with me and I need to add a device with multiple
cisco-nx-cli-3.0
snmp
netconf
how do i do that
