NSO Automation
Hello Guys,
in fact I work on the automation of NSO testing with robot framework
I finished the device configuration automation part and here is the code I used and it works
Add IOS loopback interface [Documentation] Add interface to device,
PATCH restconf/data/devices/device=${NETSIM_IOS}/config/tailf-ned-cisco-ios:interface body=${ADD_LBK_IOS}
Integer response status 204
NETSIM_IOS: netsim-io-1
ADD_LBK_IOS: {
    "tailf-ned-cisco-ios:interface": {
        "Loopback": [
                "name": 0
and I will need your help to automate the ncs command below:
administrator@ncs(config)# services SERVICE_NAME TEST001 access-device device-id netsim-io-1 interface-id 0/1
Value for 'services SERVICE_NAME TEST001 delivery-device device-id' [netsim-io-2]:
Value for 'services SERVICE_NAME TEST001 delivery-device interface-id' (<string>): 0/1/2
Value for 'services SERVICE_NAME TEST001 pw-properties customer-name' (<string>): TOTO
Value for 'services SERVICE_NAME TEST001 pw-properties pw-id' (<unsignedInt, 12000 .. 12999>): 12000
Value for 'services SERVICE_NAME TEST001 pw-properties pw-class' [PORT_PW]:
Value for 'services SERVICE_NAME TEST001 pw-properties service-rate' (<unsignedInt, 2 .. 1000>): 500
Value for 'services SERVICE_NAME TEST001 pw-properties vlan-id' (<unsignedShort, 700 .. 799>): 700
thanks a lot
0 Replies 0
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
