NSO - Juniper QFX false commit failure problem
fatbatbtegitim
Community Member
Hi all,
We are facing issue between NSO and Juniper QFX series devices. When we done commit from NSO we get back response is "commit failure" while commit was succeed on the QFXs.  Tested NSO version is 5.3 and junos versions are 18.4 and 19.4. All detailed trace logs attached from both sides
Below, you can find basic commit failure scenario
admin@ncs% set devices device dc1-leaf2 config configuration system host-name AAA
[ok][2020-08-31 10:37:10]
[edit]
admin@ncs% commit
Aborted: dc1-leaf2: "commit-results" cannot occur here as a child to 'rpc-reply'.
[error][2020-08-31 10:37:15]
while on the switch side (has been already commited);
{master:0}[edit]
root@AAA# show | compare rollback 1
[edit system]
- host-name DC1-LEAF2;
+ host-name AAA;
{master:0}[edit]
aelganzo
Could you try to increase your Juniper QFX read/write timeout
devices device <device-name>
read-timeout 60
write-timeout 60
disconnect
connect
