nso start issue
skonni
When i am try to start nso getting below error.
[root@localhost ncs-4.4.2]# ncs
Bad configuration: /home/ncs-4.4.2/etc/ncs/ncs.conf:0: "./state/packages-in-use: Failed to create symlink: no such file or directory"
Daemon died status=21
can someone please help on this
Suresh Konni
Hiro Takahashi
Hello Suresh,
You must run "nso" command under NSO instance directory (project directory).
Please create an instance directory as follows and run NSO.
test@debian:~$ mkdir ncsrun
test@debian:~$ ncs-setup --dest ncsrun
test@debian:~$ cd ncsrun/
test@debian:~/ncsrun$ ncs
Best regards,
Hiro
Hiro Takahashi
Hello Suresh,
Best regards,
Hiro
Hi Hiro,
I have the same problem but I already created run-time environment. Until some time ago it was working fine, suddenly after my machine restarted, it shows me this error. What could be the problem?
There could be a permission issue, ensure you're running ncs in your nso run folder under the designated user permission or where you installed your ncs in your local install setup.
