NSO Tail-f question: application timeout
lamt2002
I have a NSO service that moves configuration from one device to another. If there is a lot of configuration to be moved, I have run into an application timeout error during "commit dry-run". The timeout occurs roughly 2 mins after "commit dry-run" is executed. Wondering if anyone has encountered similar situation and if there is a way to change the service execution timeout ... thanks in advance.
admin@ncs% set services xxx
[ok][2018-09-12 22:17:12]
admin@ncs% commit dry-run | details
entering validate phase for running...
validate: run pre-trans-lock service callbacks...
validate: run transforms and transaction hooks... ok [0.02 sec]
validate: pre-trans-lock service callbacks done [0.02 sec]
validate: grabbing transaction lock... ok [0.00 sec]
validate: run transforms and transaction hooks... error [121.52 sec]
Aborted: application timeout
[error][2018-09-12 22:19:21]
admin@server1:/var/log/ncs$ tac ncs.log | less
<CRIT> 12-Sep-2018::22:19:21.912 server1 ncs[1391]: - Daemon ncs-dp-2273-serviceXXX:main timed out
admin@server1:/var/log/ncs$ tac devel.log | less
<ERR> 12-Sep-2018::22:19:21.914 server1 ncs[1391]: devel-c service_create error {external_timeout, ""} for callpoint 'serviceXXX-servicepoint' path /ncs:services/serviceXXX{test1}
<ERR> 12-Sep-2018::22:19:21.911 server1 ncs[1391]: devel-c Worker socket query timed out daemon 'ncs-dp-2273-serviceXXX:main' id 49
Thanks so much.
Tim
Thank you Roque for your reply.
Thanks to the suggestion by Cisco TAC to increase the following timer in NSO (default is 120 sec), the service commit dry-run is now working ...
admin@ncs% set java-vm service-transaction-timeout
(<int>) (120):
Thanks so much.
rogaglia
Hard to say without looking at your code but are you calling an external action from your service create() code? maybe opening another maapi session?
Roque
(<int>) (120):
Thanks so much.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
