_PyObject_NextNotImplemented
dretaylo
When I try to run a service on my NSO server I'm receiving the following error in ncs-python-vm.log:
2018-10-15 11:13:40 - Restarted PyVM: <<"secure-admin-asa">> , Port=#Port<0.227235> , OSpid="20828"
2018-10-15 11:13:40 - firewall-aaa-accounting :: Traceback (most recent call last):
  File "/apps/nso/opt/ncs/current/src/ncs/pyapi/ncs_pyvm/startup.py", line 6, in <module>
    import ncsctlsock
  File "/apps/nso/opt/ncs/ncs-4.4.5.4/src/ncs/pyapi/ncs_pyvm/ncsctlsock.py", line 5, in <module>
    import _ncs
  File "/apps/nso/opt/ncs/current/src/ncs/pyapi/_ncs/__init__.py", line 5, in <module>
    from _ncs_py2 import cdb
ImportError: /apps/nso/opt/ncs/current/src/ncs/pyapi/_ncs/_ncs_py2.so: undefined symbol: _PyObject_NextNotImplemented
2018-10-15 11:13:40 - Got EXIT on Port= #Port<0.227232>
2018-10-15 11:13:40 - Restarted PyVM: <<"firewall-aaa-accounting">> , Port=#Port<0.227236> , OSpid="20829"
2018-10-15 11:13:40 - secure-admin-asa :: Starting /apps/nso/opt/ncs/current/src/ncs/pyapi/ncs_pyvm/startup.py -l info -f /apps/nso/var/log/ncs/ncs-python-vm -i secure-admin-asa
    import ncsctlsock
    import _ncs
2018-10-15 11:13:40 - Got EXIT on Port= #Port<0.227235>
2018-10-15 11:13:40 - firewall-aaa-accounting :: Starting /apps/nso/opt/ncs/current/src/ncs/pyapi/ncs_pyvm/startup.py -l info -f /apps/nso/var/log/ncs/ncs-python-vm -i firewall-aaa-accounting
2018-10-15 11:13:40 - firewall-aaa-accounting ::   File "/apps/nso/opt/ncs/current/src/ncs/pyapi/ncs_pyvm/startup.py", line 6, in <module>
2018-10-15 11:13:40 - firewall-aaa-accounting ::     import ncsctlsock
2018-10-15 11:13:40 - firewall-aaa-accounting ::   File "/apps/nso/opt/ncs/ncs-4.4.5.4/src/ncs/pyapi/ncs_pyvm/ncsctlsock.py", line 5, in <module>
2018-10-15 11:13:40 - firewall-aaa-accounting ::     import _ncs
2018-10-15 11:13:40 - firewall-aaa-accounting ::   File "/apps/nso/opt/ncs/current/src/ncs/pyapi/_ncs/__init__.py", line 5, in <module>
2018-10-15 11:13:40 - firewall-aaa-accounting ::     from _ncs_py2 import cdb
2018-10-15 11:13:40 - firewall-aaa-accounting :: ImportError: /apps/nso/opt/ncs/current/src/ncs/pyapi/_ncs/_ncs_py2.so: undefined symbol: _PyObject_NextNotImplemented
2018-10-15 11:13:40 - Got EXIT on Port= #Port<0.227236>
Upon further inspection, if I just pull up a python console I get the same error importing ncs:
[dretaylo@nwsnsocvoprd-1 ncs]$ python
Python 2.6.6 (r266:84292, Aug  9 2016, 06:11:56)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-17)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import ncs
  File "<stdin>", line 1, in <module>
  File "/apps/nso/opt/ncs/current/src/ncs/pyapi/ncs/__init__.py", line 15, in <module>
    import _ncs
Has anyone received this error before?
tbjurman
Your Python version is too old for NSO. In the Developer Guide you can read:
    "Python versions 2.7.5 or higher and Python 3.4 or higher are supported"
/Tomas
Thanks Thomas! That worked 🙂
