Python Error when referencing yang variable with multiple keys
BasharAziz
Level 2
Level 2
Hi All,
I am trying to reference an xpath of service A in service B. In service B will first lookup for devicename(key) and prefix id(key)
the third key is static [public='true']:
Service A:
/services/test:test[devicename='ww']/prefixes[prefix='6000'][public='true']/ipv4Address 200.1.1.1
/services/test:test[devicename='ww']/prefixes[prefix='6000'][public='false']/ipv4Address 172.1.1.1
Service B:
vars.add('ipv4Address', f'{root.services.devicename[service.Service_B_devicename].prefixes[service.prefix][public == "true"].ipv4Address}')
template.apply('netaccessevc-prefix-ipv4-template', vars)
 I am getting this error:
errors: reason: Python cb_create error. badly formatted or nonexistent path (8): Bad key "6000" (wrong number of identifiers) at: /services/test/prefixes
2 Accepted Solutions
vleijon
The syntax for multi-key lists in the python api is [(key1, key2)]. So slightly different from xpath.
gmuloche
Looks like you are trying to get the value of the leaf
root.services.devicename["ww"].prefixes[6000,"true"].ipv4Address
 inside the variable for your templates.
Couple of points here:
* As @vleijon mentioned the correct way to reference the leaf should use the python syntax for multi key list (you can look it up there: https://developer.cisco.com/docs/nso/guides/#!python-api-overview/maagic-api - subsection List and List Elements - there is no anchor at this hierarchy level so cannot point you to it directly)
* You actually don't need the f string
From what I understand from your model, a possible resolution in service B would be:
vars.add('ipv4Address', root.services.devicename[service.Service_B_devicename].prefixes[service.prefix,"true"].ipv4Address)
which *SHOULD* put the value of the leaf ipv4Address for (6000, "true") inside the variable you are then using in your template.
vleijon
baziz1
Community Member
prefixes Is a list with two keys: prefix and public.
prefix is will be selected in service B, while public is always true.
gmuloche
