Swagger UI integration with NSO
equinix
I'm trying to integrate Swagger UI with NSO as I've seen that it should be possible starting from NSO version 4.7.
I managed to generate a swagger specification using yanger, as explained in the NSO Northbound 4.7.4.1 PDF but when trying to run the requests via Swagger UI, the same error keeps popping up:
Server response
CodeDetails
Undocumented
TypeError: Origin http://127.0.0.1:8081 is not allowed by Access-Control-Allow-Origin.
Has anyone faced this issue before?
Best regards,
Gabriel
lmanor
Hello Gabriel,
This is because of enforced CORS.
The workaround is to install appropriate browser add-on and enable it while working with the swagger- editor.
Chrome add-on: Allow-Control-Allow-Origin:*
Firefox add-on: CORS Everywhere
See also https://www.scribesoft.com/blog/2018/05/rest-connector-oas-swagger/.
-Larry
