Sync-from error: Device does not have a Network Element Driver registered
Hey NSO Folks,
We are seeing working on an NSO 4.4.2 RHEL deployment and keep hitting issues with a portion our IOS devices with IOS-Ned 5.4.2
We have associated a NED inside device-type with the proper NED and ports but when we go to sync from numerous devices pipe back: Device does not have a Network Element Driver registered
We have yet to find a commonality between the devices other than IOS, wanted to ask if anyone of this mailer has seen this issue or similar?
Also, when issuing a package reload we see:
reload-result {
    package cisco-ios
   result false
    info --ERROR--
reload-result {
    package cisco-iosxr
    result false
    info --ERROR--
reload-result {
    package cisco-nx
    result false
    info --ERROR--
reload-result {
    package dell-ftos
    result false
    info --ERROR--
reload-result {
    package juniper-junos
    result true
Brandon
Jan Lindblad
The issue here is very likely related to the JavaVM, since all the Java packages are failing, while the Junos NETCONF NED (which doesn't use any Java) is fine. Since you have quite a few NEDs, and some large ones, the issue is almost certainly that the JavaVM is out of memory/heap space.
You might see some more detailed error messages if you do a
show packages package oper-status
In order to increase the Java heap size, there are a couple of options. You could
- set the environment variable   NCS_JAVA_VM_OPTIONS=-Xmx 1G   (the default is 512MB) right before you launch ncs
- edit the   bin/ncs-start-java-vm   NSO JavaVM start script to use this number by default
- use the   java-vm start-command   to configure NSO to use some home made script to start a JavaVM, where you pass the -Xmx option to the actual JavaVM
6 Replies 6
Jan Lindblad
Hi Jan,
I'm working with Brandon to resolve this issue. I'm attempting option two of editing the ncs java vm options file, for our red hat vm would you be able to be a bit more specific of where I would modify within the file?
Elliot Wise
Maybe add the below just after the opts= line?
opts="${NCS_JAVA_VM_OPTIONS}"
# Next line added by me; to increase JavaVM heap size to support more NEDs
opts=`add_if_not_contains "${opts}" "-Xmx" "" "1G"`
Having same issues:
admin@ncs# devices connect
connect-result {
    device r0
    result false
    info Device r0 does not have a Network Element Driver registered
admin@ncs# show packages package oper-status
        PACKAGE
                         PROGRAM                                                        META     FILE
                         CODE                        JAVA           BAD NCS  PACKAGE  PACKAGE  CIRCULAR    DATA     LOAD   ERROR
NAME                 UP  ERROR    UNINITIALIZED  VERSION  NAME     VERSION  DEPENDENCY  ERROR    ERROR  INFO
cisco-iosxr-cli-3.5  -   -                    X
packages package cisco-iosxr-cli-3.5
package-version 3.5.0.7
description     "NED package for Cisco IOS XR"
ncs-min-version [ 3.2.2 3.3 ]
directory       ./state/packages-in-use/1/cisco-iosxr-cli-3.5
component cisco-ios-xr
  ned cli ned-id  cisco-iosxr-cli-3.5
  ned cli java-class-name com.tailf.packages.ned.iosxr.IosxrNedCli
  ned device vendor Cisco
NAME      VALUE
show-tag  interface
build-info date "2019-10-16 16:22:13"
build-info file cisco-iosxr-cli-3.5-source-3.5.0.7.tar.gz
build-info arch .linux.x86_64
build-info java "compiled Java class data, version 50.0"
build-info package name cisco-iosxr-cli-3.5
build-info package version 3.5.0.7
build-info package ref 3.5.0.7
build-info package sha1 This_Is_An_Example_NED
build-info ncs version 5.2.1_HEAD
build-info ncs sha1 This_NED_should_not_be_used
oper-status java-uninitialized
sbarvick
The ncs-java-vm.log often has the answer too (if the memory issue is not it).   It could also be the packages compiled under a new JDK version or dependent libraries that weren't in the packages or packages that were not actually compiled.
raranjee
I also received this error "Device ECI-API does not have a Network Element Driver registered"
# check the sync status of device
root@ncs# devices device ECI-API check-sync
result error
info Device ECI-API does not have a Network Element Driver registered
# Java JDK version was also ok    openjdk version "1.8.0_252"
# I was getting java uninitialized for most of the installed packages .
root@ncs# show packages package oper-status
# Check the ncs status
[root@sit-rfs2 init.d]# ncs --status | grep status
status: started
id=get-rpc-status ** not registered
id=get-service-status ** not registered
id=link-status-ap ** not registered
# I tried starting java-vm which failed to start
root@ncs# show java-vm status
java-vm status timeout
root@ncs# show java-vm start-status
java-vm start-status failed
# Lastly i stop start NCS deamon which solved the problem and device was in-sync .
/etc/init.d/ncs status
/etc/init.d/ncs stop
/etc/init.d/ncs start
# Again check the status of sync for device
result in-sync
Ranjeet
