Unable to Subscribe for Notifications
abhinavr5289
HI,
I am unable to subscribe netconf notifications, can someone help to configure it?
admin@ncs# show devices device <Device Name> netconf-notifications
FAILURE
NAME STATUS REASON ERROR INFO
MY_1 failed subscribe Failed to check for subscription replay support
Also, is NSO supports only Replay as "from-date-time" only , not till date/End time?
admin@ncs(config-subscription-MY_1)# replay ?
Possible completions:
from-date-time <cr>
Abhinav R
6 Replies 6
perander
NSO can't check if the device supports replay or not.
Does the device actually support replay? What kind of
NED is used?
NSO currently only supports replay start-time for netconf
notifications from devices.
Hi @perander,
Yes, the device support Notifications . I have checked from other browsers.. but I want to configure from NSO.
Can you please guide me here, how to subscribe for notifications ? and replay.
Hi @perander ,
Can you please help with the above comment.
Abhinav R
Hi!
What type of NED are you using? CLI, generic, NETCONF?
/Per
Hi @perander ,
i am using Netconf NEDs.
Abhinav R
vleijon
Do you have the ned loaded with the right notification structure? That might be the most common cause.
Try show devices device <device-name> module and make sure you see the module that contains the notification.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
