Unable to Subscribe for Notifications
abhinavr5289
HI,
I am unable to subscribe netconf notifications, can someone help to configure it?
admin@ncs# show devices device <Device Name> netconf-notifications
FAILURE
NAME STATUS REASON ERROR INFO
MY_1 failed subscribe Failed to check for subscription replay support
Also, is NSO supports only Replay as "from-date-time" only , not till date/End time?
admin@ncs(config-subscription-MY_1)# replay ?
Possible completions:
from-date-time <cr>
Abhinav R
6 Replies 6
perander
NSO can't check if the device supports replay or not.
Does the device actually support replay? What kind of
NED is used?
NSO currently only supports replay start-time for netconf
notifications from devices.
Hi @perander,
Yes, the device support Notifications . I have checked from other browsers.. but I want to configure from NSO.
Can you please guide me here, how to subscribe for notifications ? and replay.
Hi @perander ,
Can you please help with the above comment.
Abhinav R
Hi!
What type of NED are you using? CLI, generic, NETCONF?
/Per
Hi @perander ,
i am using Netconf NEDs.
Abhinav R
vleijon
Do you have the ned loaded with the right notification structure? That might be the most common cause.
Try show devices device <device-name> module and make sure you see the module that contains the notification.
