Using PYANG to help with JSON format
previousqna
Level 8
Level 8
All,
I’m struggling to get a rest call working for a service.
I consistently get a 400 status code that I’m guessing means my json payload is structured incorrectly.
I initially deployed the service via ncs_cli and used a “Show services …” | display JSON as a template for use in my python script.
That didn’t change the error.
Can pyang convert directly from a source .yang file to a JSON format?
I’m unable to find it documented and don’t find the option using pyang –help.
13 Replies 13
previousqna
Level 8
Level 8
Unfortunately, pyang cannot directly convert to JSON format for now.
Pyangbind might help you. It takes a little time, but It's very useful.
https://github.com/robshakir/pyangbind
Please refer to the below chapter:
Serialising a Data Instance
import pyangbind.lib.pybindJSON as pybindJSON
# Dump the entire instance as JSON in PyangBind format
print(pybindJSON.dumps(oclr))
This code snippet output JSON format data stratucure.
I am also using the library for automatically documentation from yang.
Use PYANG to create REST Doc
    mkdir -p ../doc/rest
     pyang -f rest-doc --rest-doc-output=docbook --rest-doc-path=/sample --rest-doc-show-description -p $NCS_DIR/src/ncs/yang/:./yang/ yang/*.yang -o ../doc/rest/sample-doc.txt
Use XSLTPROC to create REST XTML GUIDE
xsltproc -o ../doc/rest/sample-doc.html -v docbook.xsl ../doc/rest/sample-doc.txt
You can use pyang to create xml payload and then use one of the readily available xml->json tools found on-line.
Or perhaps we can help you determine the problem in the rest call/json payload that you currently have, if you provide the info here.
The show services… approach should result in accurate json payload.
Another approach would be to create a service instance using the CLI, then read the instance using a rest call to see the format.
Commas and curlies will kill you….
How can I create xml from yang. can you please give some inputs.
I tried with pyang sampl-xml-skeleton, but I am not able to produce the output.
Thanks in advance.
Hello Sujani,
Please try "-f yin" option as follows.
cisco@debian:~/NSO-4.5/examples.ncs/service-provider/mpls-vpn/packages/l3vpn/src/yang$ pyang -f yin l3vpn.yang
/home/cisco/NSO-4.5/src/ncs/yang/tailf-ncs-devices.yang:22: warning: imported module tailf-ncs-monitoring not used
<?xml version="1.0" encoding="UTF-8"?>
<module name="l3vpn"
        xmlns="urn:ietf:params:xml:ns:yang:yin:1"
        xmlns:l3vpn="http://com/example/l3vpn"
        xmlns:inet="urn:ietf:params:xml:ns:yang:ietf-inet-types"
        xmlns:tailf="http://tail-f.com/yang/common"
        xmlns:ncs="http://tail-f.com/ns/ncs">
  <namespace uri="http://com/example/l3vpn"/>
  <prefix value="l3vpn"/>
  <import module="ietf-inet-types">
    <prefix value="inet"/>
  </import>
  <import module="tailf-common">
    <prefix value="tailf"/>
  </import>
(snip)
Best regards,
Hiro
Hi Hirotsugu,
Thanks for the response.
I need xml format same as service instance xml format for the given yang. I tried using yin and format is different.
Ex:
module l3vpn {
   container switch {
       leaf access {
Xml fomat:
<switch>
  <access>true</access>
</switch>
Sujani.
Hi Sujani,
I don't think that's possible.
If we generate XML from YANG, that means you'll get a data format without any value.
On the other hand, XML in a service instance has an actual value.
There is no way to complement the value from YANG file.
Let's see your example.
module l3vpn {
   container switch {
       leaf access {
What you can get here is a container named "switch" and a leaf named "access".
There is no way to find out the leaf "access" has a value "true" as you mentioned.
I think the only way to achieve your goal is to use dry-run outformat=xml via CLI, REST or any NSO APIs.
Best regards,
Hiro
yeah, I just need xml (with out any values is also fine) as you mentioned. Here I don't have an option to create service instance and take out format xml from cli or any other approaches.
I tried with sample-xml-skeleton-defaults using pyang. But not working.
How about using -f rest-doc
MMALYSZ-M-60YE:yang mmalysz$ pyang -f rest-doc --rest-doc-output=patch sample-cfs.yang
# container /samplecfs:cfs-sample
PATCH /api/running/cfs-sample
Content-Type: application/vnd.yang.data+json
  "cfs-sample" : {
    "sample-service-list" : {
      "sample-service-id" : "<<SAMPLE-SERVICE-ID>>",
      "sample-service-state" : "...",
      "param-1" : "param-1 value"
Then you can use json2xml
https://github.com/mbj4668/pyang/wiki/XmlJson
Yeah, I was able to create JSON using rest doc. From this thread, some one replied saying, we can also generate xml from yang. Tying to find if I can directly generate xml.
But had issues with json2xml. Trying to figure it out.
root@vm--003:~# pip install json2xml
Requirement already satisfied: json2xml in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied: xmltodict==0.11.0 in /usr/local/lib/python2.7/dist-packages (from json2xml)
Requirement already satisfied: six==1.11.0 in /usr/local/lib/python2.7/dist-packages (from json2xml)
Requirement already satisfied: dict2xml==1.5 in /usr/local/lib/python2.7/dist-packages (from json2xml)
Requirement already satisfied: requests==2.18.4 in /usr/local/lib/python2.7/dist-packages (from json2xml)
Requirement already satisfied: urllib3<1.23,>=1.21.1 in /usr/local/lib/python2.7/dist-packages (from requests==2.18.4->json2xml)
Requirement already satisfied: idna<2.7,>=2.5 in /usr/local/lib/python2.7/dist-packages (from requests==2.18.4->json2xml)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python2.7/dist-packages (from requests==2.18.4->json2xml)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python2.7/dist-packages (from requests==2.18.4->json2xml)
root@vm-schalaga-003:~# json2xml
json2xml: command not found
Found following solution
pyang -f jtox -o employee.jtox employee.yang
json2xml -t config -o employee.xml employee.jtox sample_employee.json
Give https://gitlab.com/nso-developer/rest-api-explorer a try: create JSON or XML payload automatically by clicking the parameters you want to include.
