Will nso have api can directly operate devices, without using the service
syuefeng
Hi experts,
Will nso have northbound api (like REST) can directly config devices, without using the service,    in other words, I do not need to define the service to operate the device,the effect is similar to config device directly on the nso cli?
thanks.
KJ Rossavik
Yes, the NSO NBIs - RESTCONF, NETCONF, etc. lets you interact with any YANG model in the system - device models (from the NEDs) as well as service models.
Hi KJ,
Cloud you give me some reference about these API? Thanks.
please refer to the API guide in your NSO installation, under the docs directory
you can also find a number of examples here on the NSO Developer Hub. just search for RESTCONF
https://community.cisco.com/t5/custom/page/page-id/search?filter=location:5672j-dev-nso&q=restconf&mode=
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
