yang-patch with JSON data
tcragg1
I've been trying to use the yang-patch method with JSON data to write changes to device configurations in NSO, but have been having trouble making it work. Below is the JSON data I am trying to send to /restconf/data to configure an IOS device:
  "ietf-yang-patch:yang-patch": {
    "patch-id": "test-patch",
    "edit": [
        "edit-id": "test1",
        "operation": "merge",
        "target": "/tailf-ncs:devices/device=hs4-inf-p-rr01/config/tailf-ned-cisco-ios:interface/GigabitEthernet0%2F0%2F5.51",
        "value": {
          "tailf-ned-cisco-ios:GigabitEthernet": [
              "name": "0/0/5.51",
              "description": "Test",
This just returns a malformed-message error. When I attempt the same thing using XML with the following data, it works correctly:
<yang-patch xmlns="urn:ietf:params:xml:ns:yang:ietf-yang-patch">
  <patch-id>test-patch</patch-id>
  <edit>
    <edit-id>test1</edit-id>
    <operation>merge</operation>
    <target>/tailf-ncs:devices/device=hs4-inf-p-rr01/config/tailf-ned-cisco-ios:interface/GigabitEthernet=0%2F0%2F5.51</target>
    <value>
      <GigabitEthernet xmlns="urn:ios"  xmlns:ios="urn:ios"  xmlns:ncs="http://tail-f.com/ns/ncs">
        <name>0/0/5.51</name>
        <description>Test</description>
      </GigabitEthernet>
    </value>
  </edit>
</yang-patch>
Can anyone advise what I am doing wrong with the JSON?
5 Replies 5
rogaglia
Could it be that:
"description": "Test",   <--- remove final comma
Unfortunately not, I still just get a malformed message error if I remove that comma and re-try.
perander
I could reproduce this with a toy example. It seems to be bug and I filed a ticket for it.
Was this ever fixed? Seeing the same problem on 5.3.2.4.
chopps
Community Member
I realize this is 5 years later so probably not helpful, but I landed here searching for help with something else and noticed what might have been your problem.. In your JSON example, your target value is missing an `=` between the interface node name "GigabiteEthernet" and the key "0/0/5.51". In your XML example (which you said works) you did include the `=` sign.
