Observability Discussions
Share your questions, use cases, and knowledge around observability and monitoring.
Folks,            I have successfully installed the observability package that comes with 6.3 in a NSO container image. From the published documentation I cannot find a working configuration for data export. The documentation https://developer.cisco....
l2vpnethernet ring g8032 ECR_Majorexclusion-list vlan-ids 50,2114,2115,2312,2310above command is working in dry run and failing in commit for NED: cisco-iosxr-cli-7.50error: External error in the NED implementation for device RPURNRJNPAR006: command:...
