Ruwani O Biggers
Clicking on the NAV bar will let you jump to various sections in the RMA.
You can also Start Over or choose to Save Order.
After all sections have been completed, you will have the option to Submit Order.
It's all very well being able to save an order but how do I then recover it in order to submit it?
Ruwani O Biggers
You can view all saved orders in the SORT - Saved Order module.  If you need to add the module, please follow the instructions listed here: Adding SORT Modules to the My Cisco Workspace
silvano aires
Community Member
Hello team ,
