The 4010 switch's alarm port is a RJ-45 port. I am looking to wire the alarm output to an annunciator with a 125V DC wetting voltage so that the annunciator can monitor the alarm contact status. Can I use a RJ-45 to 8pin AV terminal converter to achieve this? Also, will the 4010's alarm port be able to handle 125V DC being applied across pins 3 and 7 of the alarm port?
