ASA 5500X Rommon Firmware File
dpas
Is anyone able to direct me in obtaining Rommon Firmware update 2.1.9.8 as mentioned in multiple threads?  ASA 5500X download section does not have this available vs the 5516X series.   I have 2 5555X units 1 with 2.1.9.5 which does have some issues with the sensors which 2.1.9.8 Rommon corrects.
Rebooting... Cisco BIOS Version:9B2C109A
Build Date:05/15/2013 16:34:44       2.1.9.8 Rommon
Booting from ROMMON
Cisco Systems ROMMON Version (2.1(9)8) #1:
Rebooting... Cisco BIOS Version:9B2C105A
Build Date:06/07/2011 08:31:32      2.1.9.5 Rommon
Booting from ROMMON
Cisco Systems ROMMON Version (2.1(9)5) #0:
6 Replies 6
balaji.bandi
what are you running on - is this ASA with SFR Modules ?
can you post the show version, and show the modules?
Look at the compatible version :
https://www.cisco.com/c/en/us/td/docs/security/asa/compatibility/asamatrx.html#id_59075
BB
dpas
To clarify on my post inquiry, I am only looking to find a Rommon download to complete this upgrade.  SFR firepower, installation guide to the rommon is not what I am seeking.  I am only looking for the upgrade file ex. 2198.SPA file.
still i look forward below output - i can answer any better
BB
dpas
Cisco Adaptive Security Appliance Software Version 9.14(4)17
SSP Operating System Version 2.8(1.191)
Device Manager Version 7.19(1)
Compiled on Wed 19-Oct-22 05:28 GMT by builders
System image file is "disk0:/asa9-14-4-17-smp-k8.bin"
Config file at boot was "startup-config"
BIOS Flash MX25L6445E @ 0xffbb0000, 8192KB
Encryption hardware device : Cisco ASA Crypto on-board accelerator (revision 0x1)
Boot microcode : CNPx-MC-BOOT-2.00
SSL/IKE microcode : CNPx-MC-SSL-SB-PLUS-0005
IPSec microcode : CNPx-MC-IPSEC-MAIN-0026
Number of accelerators: 1
Baseboard Management Controller (revision 0x1) Firmware Version: 2.1
------------------ show module 0 detail ------------------
Card Type: Cisco ASA 5555 Appliance with 8 GE ports, 1 GE mgmt
Model: ASA5555
Hardware version: 1.0
Serial Number: FCHXXXXX
Firmware version:
Software version: 9.14(4)17
MAC Address Range:
Data Plane Status: Not Applicable
Console session: Not ready
Status: Up Sys
Baseboard Management Controller (revision 0x1) Firmware Version: 2.4
Card Type: ASA 5555-X with SW, 8 GE Data, 1 GE Mgmt
Model: ASA5555
Serial Number: FCHXXXXXX
Firmware version: 2.1(9)8
MAC Address Range:
Status: Up Sys
Jo49201
Information about the FTD code, might be the same thing for asa image upgrade.
  ROMMON Software Boot Image System Software
Purpose To update the firmware of an ASA. To load an ASA with the network config, download the system software, and begin setup. To install the features of the FTD system.
Low-end ASA (5506-X, 5508-X, 5516-X) Firmware release 1.1.8 or greater is required. Use the *.SPA file to upgrade firmware. Use a *.lfbff file to load a low-end ASA with the FTD boot image. Use a *.pkg file to install the FTD system software package. You can use the same system software package on any low-end and midrange ASA hardware models.
Midrange ASA (5512-X, 5515-X, 5525-X, 5545-X, 5555-X) Not necessary to update the default firmware version. Use a *.cdisk file to load a midrange ASA with the FTD boot image.
I was wondering the same question.... for the 5555.
Not sure if you already upgrade yours.
Source:
https://www.ciscopress.com/articles/article.asp?p=2916289
From the upgrade guide.
Rommon is missing in mid range
https://www.cisco.com/c/en/us/td/docs/security/asa/upgrade/asa-upgrade/planning.html
