DCHP failed. APIPA is being used problem in packet tracer
AdamK729
"Hello,
I am working on a lab assignment of a 3-floor network pattern in Packet Tracer. Although DCHP config is working for floor 2 and 3, whenever I change the IP configuration of any device of floor 1 from static to DHCP, I receive an error message stating, 'DHCP failed. APIPA is being used.' I am attaching the drive link of the zip file to this post.https://drive.google.com/file/d/1QySS_n5iumUBJcFwG9wKL9hJKl-Q_9E-/view?usp=sharing
M02@rt37
Hello @AdamK729
modify sub int on F2 Router.
Subnets towards Floor 1 are connected to Gig0/1 interface, not Gi0/0.
So modif Gi0/0.18 Gi0/0.19 and Gi0/0.20 to Gi0/1.18, Gi0/1.19 and Gi0/1.20 like this:
After that, hosts on Floor 1 should have IP ADD from DHCP.
Best regards
Martin L
you can attache pt file here but in zip format;
also, I would also try CLN  CCNA forum which is more for studying and learning techs and exam info - in case u dont get answer here.  https://learningnetwork.cisco.com/s/discussions
Regards, ML
**Please Rate All Helpful Responses **
Thank you Sir. I will attach.
M02@rt37
Hello @AdamK729
Best regards
