Showing results forĀ
Search instead forĀ
Did you mean:Ā
HELP! Packet Tracer MacOS, Router Terminal Has Annoying Voice Over BUG
hezhez
Hi I got an annoying problem, I've uninstalled PT 8.1.0 many times and even did a clean install. But every time I am opening the router in packet tracer and get into CLI. The voice over just keeps on going, disabling it did not work... Is this a bug?
Other solution I've tried:
- Updating from Catalina to Big Sur after installing PT it gave the same problem...
35 Replies 35
aaron16639
In the preferences, there should be a checkbox that says "Disable CLI text to speech" on the interfaces tab
DrDrunk3nst3in
Hi!
Top Menu -> Cisco Packet Tracer -> Preferences -> Disable CLI Texto to Speech
Shorter way: cmd + , -> Disable CLI Texto to Speech
You're welcome!
torres kevin
I was wrapping my head around the mac settings, and saw it was disabled.
It is not a Packet Tracer Bug, its a setting that should be off by default but it's not,
So I went into Packet Tracer directly .....
Go to Preferences> Interface Tab> Make sure the check mark is on >Disable CLI Text to Speech
jeffyarias
This is as simple as that. Thanks
bkeytiyev
Thank you for the solution
arielmeir1212
