Problem with DHCP in cisco packet tracer
jaglak400
Edit: nvm solved it
Hi all, im working on a assignment in packet tracer and i am pretty lost i really dont know what i have to change for my DHCP to work properly. Right now no matter what i do im getting this error: DHCP failed. APIPA is being used.
I would be very grateful if someone could look at it and see where i did mistakes. Thanks in advance
@jaglak400 this happens when your DHCP relay or client VLAN dont have proper routes to DHCP server. make sure your all VLAN interfaces have routes and connectivity to DHCP server.
Good luck
KB
@jaglak400
 either you add the device config here and prints or you attached tye Packet Tracer file so that we can see whats wrong. Only with this information you provide it is very hard to help
