02-02-2020 12:39 PM
How do i start tera term in the Packet tracer? Is tera term and the terminal program in the virtual pc the same thing?
(Absolute newbie as you can tell )
Solved! Go to Solution.
02-02-2020 05:45 PM - edited 02-02-2020 05:50 PM
Indeed, terminal on PCs is the emulator. You just have to connect a console cable between the PC and the device and you can manage it.
Now, in PT most devices have a CLI tab, which gives you direct access to the console interface. To access that tab, just double click on the device and choose the CLI tab.
