Transceiver Module Group (TMG) Compatibility Matrix
salemmahara
Level 3
Level 3
Hello there
I was going to check the compatibility between C3850-12S-E and [GLC-SX-MMD,GLC-T,GLC-TE]. but the result shows only 2 rows! surprisingly the result is totally different and complete for C3850-12S-S (IP Base Model). So, we are in trouble with our researches before the order and a rapid help would be pleasant.
Thank you everybody
Thank you Balaji
It's solved. They've changed the information .
balaji.bandi
Some time Document many have lesser information than we expect.
can we have information what you looking, comptatbility you are intrested from what model to what model ?
BB
Thank you Balaji
if this is resolved can you mark as solution, so usefull for other community members.
BB
